1 Reply Latest reply on May 7, 2017 12:22 PM by davescm
    clone tool clone the original area
    idoc34351474
      hi
      when i use the clone tool everything work fine in the start but when i get to the area were i been clone he clone the original area and not the clone area  i made.
      example :
      i use the clone tool in the background little bit above the head and clone [ to delete the head but keep the background]
      now when i get to the point when the alt ["+"]  cursor are in the area when i used the clone tool it used the original area and not the clone area. you can see another head pop out.
      the only solution i find is the use again the alt in untouched area the problem i  always need to look far away from the clone area i made.
      is this is normal ?
      you cant click alt once and just clone the area you want ? you always need keep click alt and be sure it not in the clone area ?
