10 Replies Latest reply on Jun 21, 2017 7:38 AM by Mike_Abbott
    Display and performance issues with GTX 1080 Ti
    eikonoklastes Level 4
      Is this video card not fully supported yet? I'm having the following issues with it:
      Disconnected playhead:
      Jumping to keyframes disconnects the playhead from its tail, which is pretty disorienting when working with several keyframes.
      Playback leaves a random trail of black lines:
      This one isn't a big deal, but still a bit distracting.
      Also, I haven't been able to consitently reproduce it, but I will frequently get frame drops even when everything is cached to RAM and green across the board, producing the curious message in the Info panel, "Playing from RAM (NOT realtime)
      The project itself is dead simple - 1080p 25 FPS basic text, masks and solids animation overlaid on still images and image sequences. I'm not using any plugins or effects apart from Curves and a Linear Wipe here or there. I am using the Ease and Wizz expression on some keyframes, but I've been using this for years with no performance issues.
      After Effects 2017.2 (14.2.0.198)
      Core i7 7700K
      GTX 1080 Ti (381.89 which is the latest version of drivers)
      64 GB RAM
      Media Cache set to a dedicated SSD, separate from OS and project files
      Windows 10 Pro 1703 (15063.138)
        • 1. Re: Display and performance issues with GTX 1080 Ti
          So the performance issue seems to be related to how After Effects draws the playhead on high DPI displays. I'm using a 4k monitor with a DisplayPort connection, and if I maximize the composition panel, the cached video playback is always silky smooth, even when AE is preloading the frames ahead.
          However, if I have the timeline visible, the playhead causes the stutter fairly regularly.
          This seems like the exact same issue describe here for macOS:
          After Effects 2017 CC - Preview Lagging - MacSierra
          Hopefully a Windows fix comes shortly.
          • 2. Re: Display and performance issues with GTX 1080 Ti
            I haven't heard of issues with Windows machines like you describe unless they're using a specific model of Dell monitors. What exact monitor are you using?
            • 3. Re: Display and performance issues with GTX 1080 Ti
              I'm using a pretty bad monitor, admittedly - a Samsung U28E590D, which I wouldn't recommend to anyone who isn't using it only for Office. It wasn't my call and I'm having it replaced shortly.
              Regardless, it's just the colours that are awful - the actual resolution and performance is decent. I'm running it at 4k @ 60 Hz over DisplayPort and I'm not experiencing any other performance or display issues in any other applications.
              I'm curious though - why would the monitor have any effect on AE's display performance?
              • 4. Re: Display and performance issues with GTX 1080 Ti
                I have no idea. Dell (4k) P2715Q monitors have a Multi-Stream Transport (MST) option and, if it's enabled, RAM previews don't run at full speed. Disabling it works to get RAM previews running at a solid speed.
                I've no idea why.
                Check to see if your monitor has something similar just in case.
                Also, try connecting a different monitor.
                Also, try connecting over something other than DisplayPort.
                Just to rule out other possible issues.
                • 5. Re: Display and performance issues with GTX 1080 Ti
                  Kevin-Monahan Adobe Employee
                  Hi eikonoklastes,
                  Is the most current version exhibiting this behavior? Any closer to solving this issue? Please let us know what's up.
                  Kevin
                  • 6. Re: Display and performance issues with GTX 1080 Ti
                    Hi Kevin,
                    I just (excitedly) installed the update (14.2.1.34), but unfortunately, all the above issues persist.
                    I have no progress on the disconnected playhead or the black bars, but with regards to the playback performance I strongly believe it to be linked to the display of the Cache Indicators.
                    With Show Cache Indicators on, my frame rate will frequently drop even when playing back over green, cached frames.
                    With Show Cache Indicators disabled, the frame rate never drops until playback actually catches up with the frames being cached, which is the expected behaviour.
                    As a temp workaround, I can disable the indicators when smooth playback is paramount, but having the indicators on is also very important to me.
                    Edit: there also seems to be a strong correlation between the size of the Timeline panel and general AE performance. When the Timeline panel is hidden, or even made very small, I get much better playback performance. As a workaround, I have resorted to shrinking the Timeline or maximizing the Comp panel every time before playback.
                    Also, when the Timeline panel is large, dragging the playhead is very stuttery, but when the Timeline panel is shrunk down, dragging the playhead is very smooth. This stuttery dragging extends to resizing the panels itself. When the Timeline panel is large, resizing the Timeline is very stuttery, but gets smoother when the Timeline panel is smaller.
                    This stuttery dragging does not apply to dragging the layers themselves. They move around smoothly regardless of the height of the Timeline panel.
                    • 7. Re: Display and performance issues with GTX 1080 Ti
                      That is very useful information, eikonoklastes. Thank you for sharing it. It'll help me help others on the forum with similar issues.
                      Also, PLEASE file a bug report at this link with all of that information in it. I feel it will help the AE team narrow down these last few playback issues.
                      • 8. Re: Display and performance issues with GTX 1080 Ti
                        Mike_Abbott Adobe Community Professional
                        One further contribution:
                        I've had a similar issue of the 'black lines in the timeline' when I had display scaling on in Windows 10.
                        I'm not of a Windows 10 machine as I type - so I can't give you the exact dialog info , but if you look under display settings - check that all the display settings are at '100%' - and that you've not got some unusual display scaling like 120% or something...
                        • 9. Re: Display and performance issues with GTX 1080 Ti
                          It might be too early to say for sure, but the display scaling does seem to have sorted my black bars issue!
                          I have a 4K monitor, and had my scaling set to 175% (hey, don't judge me), and AE didn't seem to like that. I've set it to 150%, which is what Windows says is recommended for my display, and AE seems much happier with that. No black trailing lines for now.
                          I am still getting disconnected playheads and poor playback and playhead scrubbing performance on large Timeline panels though, even with my display scaling set to 100%.
                          Here is a video of the issue:
                          https://1drv.ms/v/s!AhyOTAuOwz3Hl-JerIL1AEf-5ATRrg
                          • 10. Re: Display and performance issues with GTX 1080 Ti
                            Not that it helps - but you have my sympathy. These sort of things can be a pain to troubleshoot.
                            I realise it's a lot of hassle - but would it be worth swapping out your 1080Ti for your old card - if you still have it - just to check if it absolutely is card related?
