I have downloaded both 34bit and 64 bit version and this is the response I get when I click on the exe file.
Can someone help me to find out what the problem is, so that I can open and use the program.
Many thanks
Lynette Gray
Women in Workboots
start at the top and work your way down applying applicable fixes until your problem is resolved.
if cc (win): https://helpx.adobe.com/creative-cloud/kb/creative-cloud-desktop-application-failed.html
if osx 10.12 (sierra), https://helpx.adobe.com/creative-cloud/kb/install-creative-suite-mac-os-sierra.html
if, your error is:
"Installer failed to initialize. File not found." or "Installer failed to initialize. This could be due to missing files."
first, rename OOBE Folder to OOBE.old.
to find OOBE:
64 bit win OS: Program Files x86\Common Files\Adobe\OOBE
32 bit win OS: Program Files \Common Files\Adobe\OOBE
mac os: HD>library>application support>adobe>caps
mac os: USER>library>application support>adobe>OOB
if that fails or isn't the exact error you see, uninstall, clean (http://www.adobe.com/support/contact/cscleanertool.html) and reinstall.
if you're using a dvd to install:
copy the disc contents to a desktop directory and install from that directory.
if you're using a mac:
1. Try to Create a new user account in Mac with Administrator Priviledges.
2. Login to the New user, Navigate to Mac HD> Application> Utilities> Adobe Installer folder, Locate products like Adobe Reader, Adobe Flash, Adobe Air and un-install them
3. Navigate to User Library> Application Support> Adobe and move Adobe to Trash.
4. Navigate to Mac HD> Library> Application Support> Adobe and move Adobe to Trash.
5. Start the installation again.
if everything applicable above fails, check your installation logs:
http://helpx.adobe.com/photoshop-elements/kb/troubleshoot-install-using-logs-elements.html
Same here. I downloaded it on two different computers. Both give this same error. The program failed to initialize.
I tried uninstalling the Creative Cloud but it asks me to uninstall all my Adobe applications. Can not just uninstall the Creative Cloud App by itself. It says other Adobe programs depend on it so won't let me uninstall it.
So none of the ideas you have suggested work.
How does one install this program? Have you fixed this error yet? BTW, one of my laptops is brand new with only Adobe s/w on it.
os?
Windows 10, on both computers.
Yes I should have thought to mention it.
Thanks.
Here is he dialog box I get when I try to run it from the downloaded folder. Not sure if thats even a legal way, but thought I would try it.I right I clicked on set up and then selected "RUN". I got the following blank looking dialog box.
what's the error when you start installation normally?
