heelo im have ae 2017
pc
cpu 6850 k
gpu nividia 1080 ti 11 gb
ram 64 gb 3000 mhz
in every composition thad i do even a 10 sec with one effect or even a text a have to wait alot of time to render all the time
not realtime ram preview
any suggestion any solution plzzzz help meee
ssd 500 gb
Purge your memory and caches.
i try to do this but its not useful!!1
Could you please describe your issue in more detail?
Is your composition set to use the classic renderer, C4D renderer, or ray-traced renderer?
Also, all of this information.
classic composeition , the problem that i cant work with realtime preview even if i make text with one effect or any position i have to wait a many time to render
Still facing this issue AhmadA?
Kevin
Can you help plzzzzzz
So, you create a 1920x1080 composition, put it a text layer with a standard font, and when you run a preview it doesn't go in real time? Is that what you are saying?
If not, please explain in a lot more detail what you are doing.
A said its in atext cause its a simps thing he cant do it
is it just slow, or are you getting an error message?
NO eror justslow
You can give this a try for better preview performance:
if you go to the "Preview window" (Ctrl + 3)
Are you saying it is slow to cache the preview or are you saying that after the preview is cached (and you get a green line over the top of everything) it won't play back in real time?
It takes alot of time to get full green line
i cant see a ral time preview
Its not help me if i but in quarter
Yes untill noww!!!!
