3 Replies Latest reply on May 9, 2017 3:09 AM by Bernd Alheit
    Page number added as a text field jumps when user clicks it
    aijazf8064518
      I have added a text field at the end of the pdf page (through a javascript) that adds page number to the pdf. I have made this text field read only. However, after the PDF is generated, whenever the user clicks on the page number, it jumps from its location. Is there a way to make it stable so that it doesn't jump on click? I tried using flattenpages(), but it disables the links. Is there any other solution?
      My code:
      var inch1 = 2570;
            for (var p = 1; p < doc.numPages; p++) {
            // put a rectangle at .2 inch, .2 inch
            var aRect4 = doc.getPageBox( {nPage: p} );
            aRect4[0] += .2*inch1;                  // from upper left corner of page
            aRect4[2] = aRect4[0]+.5*inch1;   // Make it .5 inch wide
            aRect4[1] -= .2*inch1;
            aRect4[3] = aRect4[1] - .2*inch1; // and .2 inch high
            var f4 = doc.addField({
            cName:  "p."+p,
            cFieldType: "text",
            nPageNum: p,
            oCoords: aRect4 });
            f4.textSize = 8;
            f4.textColor = color.black;
            f4.strokeColor = color.white;
            f4.textFont = font.Helv;
            f4.value = String(p);                // page numbering is zero-based
            f4.readonly = true;
            f4.borderStyle = border.u;
