3 Replies Latest reply on May 10, 2017 3:08 AM by Rick Gerard
    Attaching an image to a moving Green Screen
    JosephJamesPhoto
      So I have this idea of having my actor tear the screen that the viewer is watching in half and then holding it in their hand as they talk. How do I attached a video to the green screen so that it keeps the shape and position of the green paper that the actor will actually be tearing and holding?
        • 1. Re: Attaching an image to a moving Green Screen
          Read up on traditional 2D tracking methods and how to use markers.
          Mylenium
          • 2. Re: Attaching an image to a moving Green Screen
            JosephJamesPhoto Level 1
            So my plan is to use green screen paper, so when they are holding it at their side the way paper would be after being ripped, it'll still hold true to the video I attach using tracking?
            • 3. Re: Attaching an image to a moving Green Screen
              The solution is layers and tracking. You will have to track the left side of the paper and the right side, then attach each side to a copy of the video. I would suggest corner pin tracking in Mocha. If the paper curves when it is torn, which is likely, you'll probably also need to add some distortion effects and maybe even a shadow or two to sell the effect. I probably would not use a green sheet of paper unless the shot was very long because roto on just the fingers wouldn't take very long and a sheet of paper with some a good cross hatch on it, maybe lines about 1 inch apart, would give you more information to use to bend your video to match the bends in the paper. A green sheet of paper, even with some tracking marks on it will only save you the roto time and the shot will look more fake than if you have a grid to work with.
              I'd probably use this technique on both the left and right side of the paper:
