10 Replies Latest reply on Dec 5, 2017 8:38 PM by JJMack
    Watermark Script
    benjamink78098692 Level 1
      Hi! I am in Photoshop now and would like to make an script for placing watermarks so that they take up 10% of the width of the image and are placed so that they are 3% in from the left and 3% from the bottom on the canvas. How do I do this?
        • 1. Re: Watermark Script
          It should be easy to modify the script I have posted it places the watermark on the bottom right not the left.  You would need to change the last transform..
          #target photoshop;
          app.bringToFront();
          var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
          var LogoSize = 10; // percent of document height to resize Watermark to
          var LogoMargin = 1;                                         // percent of Document height the Watermark should have as a margin
          placeWatermark(logoFile, LogoSize, LogoMargin);             // Place Watermark  into the bottom right of document
          function placeWatermark(Image,Size,Margin){
            if(!documents.length) return;   // if no document return
            try{
            var doc = app.activeDocument; // set Doc object to active document
            app.displayDialogs = DialogModes.NO; // Dialog off
            var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
            var strtTypeUnits = app.preferences.typeUnits; // Save Users Type units
            app.preferences.rulerUnits = Units.PIXELS; // work with pixels
            app.preferences.typeUnits = TypeUnits.PIXELS; // work with pixels
            var fileObj = new File(Image);                 // the passed file
            if(!fileObj.exists){   // If file does not exits tell user
            alert(fileObj.name  + " does not exist!");
            return;
            placeFile(fileObj); // Place in file the Watermark png file
            activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
            var SB = activeDocument.activeLayer.bounds; // get layers bounds
            var layerHeight = SB[3] - SB[1]; // get layers height
            var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
            activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
            SB = activeDocument.activeLayer.bounds; // get resized layers bounds
            activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
            var LayerWidth = (SB[2].value - SB[0].value);
            var LayerHeight = (SB[3].value - SB[1].value);
            marginSize = Margin/100*doc.height.value; // move resized watermark into the document lower right corner with some margin
            activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));
            catch(e) { alert(e + ': on line ' + e.line); } // inform user of error
            finally{
            app.preferences.rulerUnits = strtRulerUnits; // Restore user ruler units
            app.preferences.typeUnits = strtTypeUnits; // Restore user type units
          function placeFile(placeFile) {
              var desc21 = new ActionDescriptor();
              desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
              desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
              var desc22 = new ActionDescriptor();
              desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
              desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
              desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
              executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
          • 2. Re: Watermark Script
            Do you know if I could use a psd or ai file instead of the png so that it will come in with layers?
            • 3. Re: Watermark Script
              You can use any image file type you want the watermark layer will be a single smart object layer.  The Laye embedded object can be a layered file like PSD , PSB or TIFF.  If  it is you can open the embedded object is Photoshop.  The disadvantage is the Layered embedded file will be larger then a flat file like png.  This will just make your watermark layered image file size  larger than need. IMO the no good reason to have a layered smart object.  You can of still have your Logo master file a layer file to make ir easy to update. IMO you should save a png file as well as your PSD and watermark using the PNG file not the layered file.
              • 4. Re: Watermark Script
                matthews63743827 Level 1
                Is there a way of modifying this script so that it embeds the smart object after placing it?
                Thanks!
                Mat
                • 5. Re: Watermark Script
                  The way place works is it uses your file full resolution to render Pixels for you new Photoshop layer.  By default Place will create a smart object layer.  The layes's object will either contain a copy of your file or a link to your file.  The rendered layer pixels can not be changed with Photoshop tools like paint brush, erases etc.  There composite can be adjusted via smart filters. Also every Smart Object layer has an associated transform.  To scale and position the layer composite in you document.   Any time you change a smart object layers transform.  The transform is transforming the Pixels rendered for the layer. These pixels can not be changed by Photoshop tools.  The only want to change these is to open the layers object and modifying the object.  When you update the object Photoshop will render a new set of Pixels for the updated object.
                  The way the script is coded your full size file is embedded in the layers object.   You would need to change the script if you want the layer to have a linked master watermark file which make not sense if you will be saving files for the web.  They are not layered and contain no objects..
                  • 6. Re: Watermark Script
                    Oh okay. I assumed the file was added as a linked smart object that could be broken.  One more question: I can't seem to figure out how to make the logo show up on the bottom left rather than bottom right.  Is there a line of code I need to modify or add?
                    Also, how easy is it to alter this script to work in Illustrator?  A completely new script?
                    Thanks!
                    Mat
                    • 7. Re: Watermark Script
                      I posted two version of the script here is a link to the one you want.  Right click the link and] save the script. The formatting should look better; You change the statement
                      var BottomLetf = false// false = Bottom Right true Bottom Left
                      Looks like Jive has changed again you man nee to uset the link and then right click save as in the page..
                      http://www.mouseprints.net/old/dpr/PlaceWatermark.jsx
                      • 8. Re: Watermark Script
                        Thanks!
                        • 9. Re: Watermark Script
                          Chuck Uebele Adobe Community Professional & MVP
                          As far as Illustrator, you would need to write a new script. They're not interchangeable.
                          • 10. Re: Watermark Script
                            I do not use Illustrator one complex Adobe application is all I want.
                            If you use Illustrator I would expect that you would create your Watermark using all vector graphics in Illustrator and use that File as placed vector smart object in Photoshop.   Photoshop treats placed .AI and .SVG file as vector smart object to a point. I find that Rotation and perspective transforming is not supported with these vector smart objects.  I only hack a scripting Photoshop.
                            I don't use the bridge much so I doe not try scripting the Bridge.  If you are automating an application via a script.  The script would need to be programmed for the application being automated. Illustrator is Adobe Vector editing application.  Photoshop supports some vector tools but is basically a pixels editor.
                            I have read that Photoshop Pen tool is different then Illustrator's Pen tool.
                            I do not even load Lightroom for I do not particulary want two  RAW UI and a lightroom user need to use ACR UI in Photoshop and Lightrool RAW conversion are open into Photoshop through ACR for Lightroom Develope module is not also a Plug-in like ACR. Several Adobe Applications use ACR however Lightroom does not. Lightroom user ACR in Photoshop and Lightroon can noy use Layers.  Only a composite layer can be use from Photoshop in lightroom so when you edit a document from lightroom in Photoshop Lightroom can no longer readjust its RAW conversion for conversion has been merged into the Photoshop's edits....  So I do not install Lightroom to keep things simple.
                            Change is not always better IMO.
