1 Reply Latest reply on Sep 19, 2017 9:18 AM by springcaleb
    Adobe Acrobat DC has stopped working
    springcaleb
      We are running Windows 10 Pro and Adobe Acrobat DC Pro (version 17.9.20044.25828).
      Randomly, not even with the same PDF doc, Adobe Acrobat will crash while editing or reviewing a document with the following message
      A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
      In the Windows event logs the following are show after it crashes.
      Level: Error
      Source:Application Error
      Event ID:1000
      Task Category: Application Crashing Event
      Faulting application name: Acrobat.exe, version: 17.9.20044.25828, time stamp: 0x58e430d1
      Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
      Exception code: 0xc0000005
      Fault offset: 0x00726567
      Faulting process id: 0x20cc
      Faulting application start time: 0x01d2bf8e4248a343
      Faulting application path: C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\Acrobat.exe
      Faulting module path: unknown
      Report Id: 4d5bdbc6-135c-4ffc-b6df-7101b8c19a5c
      Faulting package full name:
      Faulting package-relative application ID:
      Fault bucket 116363751795, type 5
      Event Name: BEX
      Response: Not available
      Cab Id: 0
      Level: Information
      Source: Windows Error Reporting
      Event ID: 1001
      Task Category: None
      Problem signature:
      P1: Acrobat.exe
      P2: 17.9.20044.25828
      P3: 58e430d1
      P4: StackHash_2beb
      P5: 0.0.0.0
      P6: 00000000
      P7: PCH_05_FROM_ntdll+0x0006EB8C
      P8: c0000005
      P9: 00000008
      P10:
      \\?\T:\<file path including file name>
      \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERDD6F.tmp.WERInternalMetadata.xml
      These files may be available here:
      C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Acrobat.exe_384e666d3e6c364591 b76a19179ceffed58cac85_85170d0e_24985de9
      Analysis symbol:
      Rechecking for solution: 0
      Report Status: 0
      Hashed bucket: b9fa276da23f1926d2e4653da4ac0dfb
      We have tried uninstall (using the adobe clearn from Adobe and Revo uninstaller) with a fresh install using a new download from Adobe.com.
      This happens for 5 of 20 users.
      What could be causing this?
