2 Replies Latest reply on May 11, 2017 6:40 AM by sargums46564804
    How add height to checkbox text
    sargums46564804 Level 1
      I want to add text to following check box but it is squished.
      I tried adding height but it did not work.
                                                  type: "check_box",
                                                  item_id: "SPst",
                                                  height: 23,
                                                  char_width: 8,
                                                  name: "Save Labeled File (Retrieve from c:\\Automatically Labeled Documents. Note labeled documents \r\n will not save if this pre-created folder does not exist or if item unchecked.)",
                                                  variable_Name: "bSaveWPostFx",
        • 1. Re: How add height to checkbox text
          Joel_Geraci Adobe Community Professional
          Instead of a long phrase as the text label, create a view element with alignment_row and add the check box with no name property and use a static_text multi-line element for the label.
          • 2. Re: How add height to checkbox text
            You are right.  That is a much better solution and it works!
                                                        type: "static_text",
                                                        name: "*Retrieve from c:\\Automatically Labeled Documents.Note labeled documents \r\nwill not save if this pre-created folder does not exist.)",
                                                        height: 40,
                                                        char_width: 8,
