2 Replies Latest reply on May 11, 2017 5:21 AM by Steve Werner
    Exporting my indesign document to pdf shows blank?
    ellisak60721542
      When I try to export my indesign file to pdf it comes up with a notification (shown in attached image) and when i click continue and open the pdf it is completely blank. Please help! I need this as a pdf!!
      [Moved from the non-technical LOUNGE Forum to a Program forum... Mod]
      [Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
        • 1. Re: Exporting my indesign document to pdf shows blank?
          Hi Ellisa,
          your exported PDF is blank, because you did your artwork on master B that was not applied to any document page.
          Cut/Paste in Place your contents to the appropriate document pages.
          The message you are seeing has nothing to do with the blank PDF.
          What is your document's transparency blend space?
          What is your PDF export preset you are using?
          Regards,
          Uwe
          3 people found this helpful
          • 2. Re: Exporting my indesign document to pdf shows blank?
            Steve Werner Adobe Community Professional & MVP
            Uwe's answer is correct.
            When I teach my InDesign classes, I always teach beginners to pay attention to what page you're working on. There are two ways to tell: (1) If the Pages panel is open, always notice what page or spread is highlighted. In your screen capture, you can clearly notice that B master is highlighted. (2) If the Pages panel is not open, check the status line at the very bottom left of the screen. It will always show you the page you're working on. That's also visibile on your screen.
            2 people found this helpful
