7 Replies Latest reply on May 11, 2017 9:04 AM by Barbara Ash
    Wavy text - Maybe displacement map?
    simonb44879216 Level 1
      Hello
      Im creating a landingpage for a organization, and i would like to make wavy text for the frontpage like the text on the image.
      I have tried using displacement maps in photoshop, but it doesnt seem like i can get the text alone after i displaced it.
      Also it would be nice if i could take it further into illustrator so i can stretch it into different sizes.
      -Thanks
        • 1. Re: Wavy text - Maybe displacement map?
          davescm Adobe Community Professional
          Displacement maps work on pixels rather than vectors such as shape or text. However you can place the text inside a smart object and apply the displacement map to that smart object. That will let you open the smart object and alter the text later.
          Edit the smart object text content:
          Hope that helps you
          Dave
          • 2. Re: Wavy text - Maybe displacement map?
            Thanks!
            What do you normally use as displacement maps?
            I have a hard time finding a texture that could make my taxt look like the one on the picture
            • 3. Re: Wavy text - Maybe displacement map?
              Trevor.Dennis Adobe Community Professional (Moderator)
              simonb44879216  wrote
              Thanks!
              You have to make the map specifically for the job in hand.  We have had lots of threads on the subject here, with all the tips you'd need.  One thing I'll add regarding the image in your first post, is that after applying the Displacement Map, load the map layer again and copy it, and set one to Screen and the other to Multiply.  The resulting shading will supplement the distortion making for a much better effect.
              • 4. Re: Wavy text - Maybe displacement map?
                The displacement map is just a grey image. So make it the same size as your poster.
                Paint white to move pixels one ways - black to move the other. Then save it as an 8 bit PSD file.
                Then you just use the Filter - Distort - Displacement to move the pixels.
                So for a simple example - start with this:
                Make a displacement map like this :
                Use the displace filter with that map
                Drag in the map layer and use the shading as described by Trevor
                Dave
                • 5. Re: Wavy text - Maybe displacement map?
                  mark-heaps Adobe Community Professional
                  I would also suggest just using transform and get into the distort grid. Often you can do things very easily by just nudging parts of the grid and it's anchors.
                  I made a quick video grab for you to see how here: Warping Text.mov - Google Drive
                  By using a smart object on the text layer, it will protect the text in case you need that warp to maintain as a placeholder.
                  @lifebypixels
                  • 6. Re: Wavy text - Maybe displacement map?
                    norman.sanders Most Valuable Participant
                    A couple of years ago I posted this Tech Sheet that I had written for my students. I hope it helps you.
                    The Unique Effect of Displacement Mapping
                    Displacement Mapping is the process of changing the geometry of an image so that such things as straight lines are contoured according to the tones appearing the in image in the layer below. This is how it is done in Photoshop
                    1. Open a file
                    2. Choose Image > Duplicate. In the As: field enter file name as: filename_map.psd. (Example: man_map.psd). This file, which will ultimately serve as the Displacement Map must be in psd format.
                    3. Choose Image > Mode > Grayscale.  Increase the image contrast using Curves or Levels. Since each image is unique, there is no exact setting. Then choose Filter > Blur > Gaussian Blur. Once again, there is no set amount. The sample below is a useful guide.
                    4. Save this file – filename_map.psd -- to the desktop.
                    5. Open another file consisting of a pattern or type*. Drag that image over the full color image. It will be Layer 1. For the samples below, this was the image that was used. (You may recognize it as the Bayer array camera chip design discussed in the article related to image sharpening.)
                    * If you choose to use type for Layer 1, it must be rasterized. After typing, choose Layer > Rasterize > Type.
                    6. Choose Filter > Distort > Displace. The default numbers of 10 for Vertical and Horizontal Scale usually work very well. For greater displacement,15 is satisfactory, as well. Radio buttons should be set to Stretch to Fit and Repeat Pixel Edges. Click OK.
                    7. Choose a Blend Mode of Multiply or Overlay (the results appear on the following page). Experiment with other Blend Modes, as well. Adjust the opacity of Layer 1 for the most pleasing effect.
                    8. In the images below, a mask was added to Layer 1 by clicking on the mask symbol at the bottom of the Layers panel. Then, by painting in black on the eyes, that area of the bottom layer was revealed.
                                         Multiply                                     Overlay
                                                          Opacity at 50%
                    In the example below, the same Displacement Map was applied as had been used in the previous example. A light blue Stroke was applied to the rasterized type so that it would be readable against the black background of the image when the 100% Multiply Blending Mode was added, as shown at the bottom/right.
                    • 7. Re: Wavy text - Maybe displacement map?
                      Barbara Ash Adobe Community Professional
                      You'll need to eyeball it, but you might find it more intuitive than displacement map.
                      After typing the text, right click on the text layer and convert to smart object.
                      Choose Edit > Transform > Warp.
                      You'll get points and handles that you can move around until the text looks the way you want.
                      It's easy to edit if you need to. Just choose Edit > Transform > Warp again.
