1 Reply Latest reply on Sep 29, 2008 3:39 AM by SujitG
    Changing variable with combobox selection - simple problem!
    jarmanje Level 1
      Hi there,
      I have a search field when you click on search.
      I want to make it so i can change which field in a datagrid you search for depending on the choice in the Combbox. I'm not sure how to set the object name correctly depending on the combobox selection.
      I tried it like this, to no avail
      private var acOrder:ArrayCollection
      private var currentOrder:Object;
      ///////////////this is incorrect. What should i use instead of Object?//////
      private var whichArray:Object
      private function makeid():void
      whichArray = "orderid"
      private function makeemail():void
      whichArray = "email"
      private function filterByOrderid(item:Object):Boolean
      if (item.(whichArray) == filterTxt.text)
      ////I want this result to either be if (item.orderid == filterTxt.text)
      ///or if (item.orderid == filterTxt.email)
      return true;
      else
      return false;
      private function doFilter():void
      if (filterTxt.text.length == 0)
      acOrder.filterFunction = null
      else
      acOrder.filterFunction = filterByOrderid;
      acOrder.refresh()
      i think answer is very simple. i just need to pass the name of the item inside the object correctly
      thanks very much for any help
