0 Replies Latest reply on May 11, 2017 5:36 AM by fat_owl
    Phonegap app (PGB) fails sending push notification to ios with "invalid APN credentials."
    fat_owl
      config.xml
      <gap:plugin name=phonegap-plugin-push source=npm spec=1.9.4>
              <param name=SENDER_ID value=[from google api] />
      </gap:plugin>
      mypage.html
      var push = PushNotification.init({
            "android": {
              "senderID": "[from google api]"
            },"ios": {
              "gcmSandbox": "true",
              "alert": "true",
              "badge": "true",
              "sound": "true",
              "clearBadge": "true"
            "browser": {
              "pushServiceURL": 'http://push.api.phonegap.com/v1/push'
           push.on('registration', function(data) {
           console.log(data.registrationId);
           document.getElementById("txt_deviceid").value = data.registrationId;
           push.on('notification', function(data) {
           //alert(data.title+" Message: " +data.message);
           window.location.href="#/page1/page17";
           push.on('error', function(e) {
           alert(e);
      myserver.php(ios function)
      function sendPushIos($to,$title,$message)
        define( 'API_ACCESS_KEY', 'AIzaSyDr1-xxxxxxxxxxxxxxxxxxmw');
        $registrationIds = array($to);
        $msg = array
        'title' => $title,
        'body' => $message,
        'vibrate' => 1,
        'sound' => 1
        $notification = array
        'title' => $title,
        'body' => $message
        $fields = array
        'registration_ids' => $registrationIds,
        'notification' => $notification,
        'data' => $data,
        'priority' => 'high'
        $headers = array
        'Authorization: key=' . API_ACCESS_KEY,
        'Content-Type: application/json'
        $ch = curl_init();
        curl_setopt( $ch,CURLOPT_URL, 'https://android.googleapis.com/gcm/send' );
        curl_setopt( $ch,CURLOPT_POST, true );
        curl_setopt( $ch,CURLOPT_HTTPHEADER, $headers );
        curl_setopt( $ch,CURLOPT_RETURNTRANSFER, true );
        curl_setopt( $ch,CURLOPT_SSL_VERIFYPEER, false );
        curl_setopt( $ch,CURLOPT_POSTFIELDS, json_encode( $fields ) );
        $result = curl_exec($ch );
        curl_close( $ch );
        echo $result;
      myserver.php(android)
      function sendPush($to,$title,$message)
        define( 'API_ACCESS_KEY', 'AIzaSyDrxxxxxxxxxxxx6SwhKxQL39FeIKGmw');
        $msg = array
        'message' => $message,
        'title' => $title,
        'vibrate' => 1,
        'sound' => 1
        // you can also add images, additionalData
        $fields = array
        'data' => $msg,
        $headers = array
        $ch = curl_init();
        curl_close( $ch );
        echo $result;
      generated app id, development certificate (with push notification services), .p12 file from it and a provisioning profile. built using PGB.
      Iam getting GCM android-like registrationID (same length) from my ios app.
      works in android. but throws "InvalidAPNcredentials" in ios10 iphone5.
      Please help.
