2 Replies Latest reply on May 11, 2017 9:02 AM by timmiller.net
    New Monitor for K4000 CC2017
    timmiller.net Level 1
      Hi Guys,
      I've got a Quadro K4000 with a limitation of 2500px across. I was looking at the dell UP3017 but really want the best for what I can afford. 30 inches is about the biggest I really want...would actually not mind two 27" monitors. $700-$1000 is my range.
      Would really appreciate any input.
        • 1. Re: New Monitor for K4000 CC2017
          Bill Gehrke Most Valuable Participant
          Do you want or need 10-bit display capability--those monitors a very expensive?  That Kepler based card is several generations old and if you use the Display Port (which many current displays support) you actually could get 3840 x 2160 resolution if there really is any need for more resolution.  Also it has only 768 CUDA cores.  Except that apparently you apparently have only a PCIe Gen 2 bus, your card is a single slot width and your may have power limitations, you could consider a new graphic card and monitor upgrade.
          K4000 SPECIFICATIONS
          GPU Memory
          3GB GDDR5
          Memory Interface
          192-bit
          Memory Bandwidth
          134.0GB/s
          CUDA Cores
          768
          Max DP 1.2 Resolution
          3840 × 2160 at 60Hz
          Max DVI‑I DL Resolution
          2560 × 1600 at 60Hz
          Max DVI‑I SL Resolution
          1920 × 1200 at 60Hz
          Max VGA Resolution
          2048 × 1536 at 85Hz
          Graphics APIs
          Shader Model 5.0,
          OpenGL 4.4, DirectX 11
          Compute APIs
          CUDA, DirectCompute,
          OpenCL
          • 2. Re: New Monitor for K4000 CC2017
            Bill,
            Roger all that and thanks. Yea, I'm working on systems that are older and need a simple solution - I'm using $100 monitors and have to upload, look at another system to see what it looks like, then color correct again...and back and forth. It's a mess.
            Upgrading the card isn't really an option. Looking for a good monitor - with respect to color. 10bit is not really necessary, but we are going to upgrade the system in the future...
