Here's the script. How do i add a "bleed size" variable to it?
// https://forums.adobe.com/thread/2049382
// Main script by Loic Aigon Add highly customized Text Variables to InDesign | Ozalto
// Additions (First Page Dimensions and variable update on script execution)
// and modifications (without permission, sorry Loic) by Trevor http://www.creative-scripts.com
#targetengine 'usernameVariable'
//This function adds static text variables in InDesign
//They won't be dynamically updated though.
//That's why we need the updating function below
function toTitleCase(s) { // By Trevor
return s.toLowerCase().replace(/\b\w/g, function () {return arguments[0].toUpperCase()});
function myRound(thisNumber, digits) { // By Trevor
digits = (digits) ? Math.pow(10, digits) : 1000;
return Math.round(thisNumber * digits) / digits;
function addVariables(openEvent){
if (!openEvent) return;
var doc = (openEvent.constructor == Document) ? openEvent : openEvent.parent; // By Trevor
while ( doc.constructor.name != "Document" )
if ( doc.constructor.name == "Application" ){ return; }
doc = doc.parent;
//Adding User name to text variables
createTextVariable(doc, "User name", $.getenv($.os[0] == "M" ? "USER" : "username") ); // changed by Trevor
//Adding Computer name to text variables
createTextVariable(doc, "HD Name", (Folder.system).parent.displayName );
createTextVariable(doc, "Computer Name", getComputerName() );
//Adding a link to my website
createTextVariable(doc, "_About Loic Aigon", "Feel free to visit my website: http://www.loicaigon.com !" );
createTextVariable(doc, "_About Trevor", "Feel free to visit my website: http://www.creative-scripts.com !" ); // by Trevor
//Adding First Page Dimensions
createTextVariable(doc, "First Page Dimensions", getPageDimentions(doc.pages[0])); // by Trevor
addVariables(app.properties.activeDocument); // callback by Trevor
//Generic function to add static custom text variables
function createTextVariable(target, variableName, variableContents){
var usernameVariable = target.textVariables.itemByName(variableName);
if(!usernameVariable.isValid){
usernameVariable = target.textVariables.add();
usernameVariable.variableType = VariableTypes.CUSTOM_TEXT_TYPE;
usernameVariable.name = variableName;
usernameVariable.variableOptions.contents = variableContents;
//Snippet for grabbing the deep name of the computer
function getComputerName(){ // by Trevor
return $.os[0] == "M" ? app.doScript("get computer name of (system info)", ScriptLanguage.APPLESCRIPT_LANGUAGE) : $.getenv("computername");
function getPageDimentions(page){ // by Trevor
var width, height, bounds, units, decPlaces;
// function presumes that normal pages
// i.e. same vertical and horizontal and no page shape transformations
decPlaces = 3;
units = toTitleCase(page.parent.parent.viewPreferences.horizontalMeasurementUnits.toString()); // If you forgot to include the toTitleCase function then remove the method
bounds = page.bounds;
height = bounds[2] - bounds[0];
height = myRound(height, decPlaces);
width = bounds[3] - bounds[1];
width = myRound(width, decPlaces);
return width + " X " + height + " " + units
//Add listeners to update file when opened.
app.addEventListener('afterOpen', addVariables);
// You might like to add some or all of these to make the update better
app.addEventListener('beforeSave', addVariables); // by Trevor
app.addEventListener('beforeSaveAs', addVariables); // by Trevor
app.addEventListener('beforeSaveACopy', addVariables); // by Trevor
app.addEventListener('beforeExport', addVariables); // by Trevor
app.addEventListener('beforePrint', addVariables); // by Trevor
app.addEventListener('beforeDeactivate', addVariables); // by Trevor
app.addEventListener('afterActivate', addVariables); // by Trevor
you define bleed in the documentPreferences.
// Active document:
var doc = app.documents[0];
// Change uniform bleed size:
doc.documentPreferences.properties =
documentBleedUniformSize : true ,
documentBleedTopOffset : "3 mm"
See DOM documentation for properties of non uniform bleed sizes:
Adobe InDesign CS6 (8.0) Object Model JS: DocumentPreference
Regards,
Uwe
Hi, Uwe. Thank you for the script, but i appologize, i did not ask the question correctly. I have a slug in Indesign that pulls document information into text variables like "page dimensions", "filename", "Date", etc. I was looking to add to the script to enable another variable that picks up the "Page Bleed Size" from the "Document Setup" menu.
Did you ever find a solution to this?
Hi attil ,
as I said you'll get this information from the documentPreferences.
Simply first look after:
if that returns true, read the value for documentBleedTopOffset and either add that directly to the text frame in the slug or do another createTextVariable() and another addTextVariable() for bleed.
If it returns false you have to read out all four properties for bleed as listed here:
documentBleedBottomOffset,
documentBleedInsideOrLeftOffset,
documentBleedOutsideOrRightOffset and
and repeat the prescription I gave above.
Boiler plate code is waiting here:
Re: I need to add in a page size text variable to my already working .jsx script
Regards,
Uwe
Sorry for asking, but what would the final code look like?
The following works for me. Keep in mind that I always set a uniform bleed so grabbing top offset gives me the same value as bleeds for left, right and bottom.
var myDocument = app.documents[0];
var bleed = myDocument.documentPreferences.properties.documentBleedTopOffset;
alert ("bleed = " + bleed);
