22 Replies Latest reply on Apr 5, 2010 6:48 AM by DoctorFlash
    Problem to install FlexComponentKit.mxp
    alineFR Level 1
      Problem to install
      Hi !
      I try to install FlexComponentKit.mxp without sucess :(
      Can you help me please ?
      I try to follow the process : http://www.adobe.com/cfusion/entitlement/index.cfm?e=flex_skins
      But it doesn't work for me.
      Use the following procedure to install the Flex Component Kit for Flash CS3.
      1. Install Flex.
      2. Change the directory to install_dir/frameworks/flash-integration.
      3. Double-click the FlexComponentKit.mxp file to install the necessary files in Flash CS3.
      I don't understand the step 2 :
      I don't find this file ;(
      When I open Flash CS3, the command " Convert symbol to Flex Component " is not avalaible.
