2 Replies Latest reply on May 12, 2017 8:07 AM by Roei Tzoref
    Import strokes with pattern brush applied, into After Effects –
    ktcad Level 1
      I have strokes in a Ai. file with a bespoke pattern brush applied. When dropped into AE, and hitting Convert to Vector Shapes, it's expands into individual shapes rather than keeping the stroke (as it would if I was using a standard stroke)
      Anyway around this? I have a series of ladders all crossing and winding around each other, if I could keep them as strokes (I've specified endings & corners in the pattern brush settings in Ai) it would be much easier.
      Cheers –
        • 1. Re: Import strokes with pattern brush applied, into After Effects –
          No. You get what you ask for. A pattern brush is nothing more than that. You would see the same results when using the Expand command in AI, which the conversion function essentially boils down to.
          Mylenium
          2 people found this helpful
          • 2. Re: Import strokes with pattern brush applied, into After Effects –
            Roei Tzoref Adobe Community Professional
            the only way to get a stroke path instead of a fill is to set your brush in Ai to a uniform width and basic brush before you convert it to vector (or copy paste)
            if you have that, you will get a stroke and not a fill outline.
            a workaround to have both worlds could be:
            1. bring your layer once as pixels with the fancy brush, and a second time as a uniform-basic. then you convert only the uniform-basic to vector shape and use it to reveal the fancy brush layer by using it as an Alpha Matte.
            OR
            2. you could also copy paste the path from Ai to Ae (after you set it to uniform-basic) and use the stroke effect to reveal the fancy brush.
