5 Replies Latest reply on May 12, 2017 9:38 AM by Roei Tzoref
    Keyframe equal tangent length - how to set and/or lock?
    nickn35634941 Level 1
      Hello, another basic question I can't seem to figure out.
      Is it possible to set a keyframe to have equal tangent length? If so, how, and, is it possible to lock the tangent handle lengths?
      Am I using the wrong terminology?
      A google search returned no results for AE, and searching on this forum returned no results either..
      I thought while I am here I could also ask about another tangent handle issue which has been bugging me, why is it that I cannot move this handle all the way up to a vertical alignment? check this example of what I mean:
        • 1. Re: Keyframe equal tangent length - how to set and/or lock?
          It's not possible natively. AE has the dumbest graph editor in the world. You can set it numerically with scripts, though. I believe there is such a tool on AEScripts.com in one of those "toolbox" script collections or even a separate script, you may just have to pay for it.
          Mylenium
          • 2. Re: Keyframe equal tangent length - how to set and/or lock?
            Roei Tzoref Adobe Community Professional
            select both keyframes and use Ctrl+Shift+K (windows)
            now you can set the influence, use lock dimensions to lock x and y.
            there's a free script that can do it too: Dojo Ease Script: Easy Easing and Graph Edits in After Effects | CreativeDojo
            I am not sure exactly what you mean or trying to accomplish. if a value influence handle was completely vertical, then the layer won't actually interpolate pixels. if moving from 0 to 100 value is vertical it means it's actually just 100...
            • 4. Re: Keyframe equal tangent length - how to set and/or lock?
              Hi Roei,
              When I bring up the Keyframe Velocity panel (ctrl + shift + k) I don't get the option to lock the tangent, and from what I see on your screenshot that doesn't look like it would lock the tangent lengths either.
              When I set the influence to be equal on incoming and outgoing, the handles still look like they are at different lengths.
              Regardless, is it possible to even control both handles equally/ simultaneously?
              As Mylenium said there is probably a script somewhere I can find, that dojo one looks like its just for easing rather than the features I was asking about.
              Regarding vertical handle, it just sets the initial level of influence so I'm not sure what you mean.. It looks like you are able to set your handle vertically in that screenshot?
              I thought it would be useful to show what I mean, to be more clear when I say tangent lengths being equal / locked:
              • 5. Re: Keyframe equal tangent length - how to set and/or lock?
                I now see what you mean.
                if they are the incoming and outgoing of the same keyframe - NO, if they are handles from different keyframes - YES, you can select them together and move them together.
                it takes more effort that you need to have in your screenshot. I think that although the visual result is different and the handle does not stretch straight, it can lead to the same result.
                if you think there's some functionality missing here, please ask for in the feature request form and make Ae better for all of us. I haven't used C4D graph editor so I don't know if I am missing something: Feature Request/Bug Report Form
