2 Replies Latest reply on May 16, 2017 6:36 AM by cbeckwith
    Server Side Form Validation Page Shows HTML
    ejh2
      I saw a post about this a few years ago, but never an answer.
      We have some very old forms that use the hidden field type of server side validation to check required fields (_required).  The same forms on ColdFusion 10 return a correctly formatted validation error page.  The form under CF11 returns a page that shows the html tags.
      The form contains hidden fields like this: <input type="hidden" name="From_required" value="Name of person submitting request is required.">
      When a form is submitted with an empty field the page displayed looks like this:
      Form entries are incomplete or invalid.
         <ul><li>Name of person submitting request is required. </li></ul> Go <a href="javascript:history.back()">back</a> and correct the problem.
      I know using this type of validation isn't good, but we need to get them over to CF11 as is for now.  I tried changing the form to a cfform, but got the same results.  I also changed the _required to _cfformrequired, but no difference.
      Any ideas what may be causing this?  Any suggestions appreciated.  Thanks.
        • 1. Re: Server Side Form Validation Page Shows HTML
          BKBK Adobe Community Professional & MVP
          It is a bug. Please report it.
          In the meantime you could quickly, and simply, set up a workaround. Remove the _required, then use validation by means of jQuery.
          You may use this jQuery validation example:
          <form method="post" name="userForm">
            First name:<br>
            <input type="text" name="firstname">
            <br>
            Last name:<br>
            <input type="text" name="lastname" >
            <br>
          E-mail:<br>
            <input type="text" name="email">
            <br><br>
            <input name="sbmt" type="submit" value="Submit">
          </form>
          <script src="https://cdn.jsdelivr.net/jquery/1.12.4/jquery.min.js"></script>
          <script src="https://cdn.jsdelivr.net/jquery.validation/1.16.0/jquery.validate.min.js"></script>
          <script type="text/javascript" >
          // Wait for the DOM to be ready
          $(function() {
            // Initialize form validation on the registration form.
            // It has the name attribute "registration"
            $("form[name='userForm']").validate({
              // Specify validation rules
              rules: {
                // The key name on the left side is the name attribute
                // of an input field. Validation rules are defined
                // on the right side
                firstname: "required",
                lastname: "required",
                email: {
                  required: true,
                  // Specify that email should be validated
                  // by the built-in "email" rule
                  email: true
              // Specify validation error messages
              messages: {
                firstname: "Please enter your firstname",
                lastname: "Please enter your lastname",
                email: "Please enter a valid email address"
              // Make sure the form is submitted to the destination defined
              // in the "action" attribute of the form when valid
              submitHandler: function(form) {
                form.submit();
          </script>
          • 2. Re: Server Side Form Validation Page Shows HTML
            cbeckwith
            You're using <cfform tags?
            Chuck
