2 Replies Latest reply on May 15, 2017 11:28 AM by StevenTabor
    Adaptive Wide Angle Filter Will Not Preview
    StevenTabor
      Hello all, I am using an up to date version of Photoshop CC on an up to date Windows 7 Pro HP Z840 machine. When I duplicate a background, convert it to a smart image and initiate the adaptive wide angle filter - the image will not preview. If I turn off preview the image appears in its original form but once I turn on preview again the image just disappears. Does anyone know if there is a fix / work around? Note: 1. If I do the above on my Macbook Pro it works without issue. 2. This feature failed to work on the last version (just prior to the most recent update) as well.
        • 1. Re: Adaptive Wide Angle Filter Will Not Preview
          Which Preview? There seems to be two preview in the latest version of that filter.
          Supply pertinent information for quicker answers
          • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
          • Adobe product and version number
          • Operating system and version number
          • The full text of any error message(s)
          • What you were doing when the problem occurred
          • Screenshots of the problem
          • Computer hardware, such as CPU; GPU; amount of RAM; etc.
          • 2. Re: Adaptive Wide Angle Filter Will Not Preview
            StevenTabor Level 1
            Jjmack... thank you. I found that the issue was only happening when in the auto selection function of the filter. Once selecting another correction type from the drop-down, the preview enables. My issue is resolved.
