2 Replies Latest reply on Jun 22, 2017 11:16 AM by K.Daube
    FM-14: strange behaviour of SetUpMenu function
    K.Daube Level 2
      Friends and gurus: I encounter a very strange situation!
      The following script works correctly. The functions are called by a button.
      #target framemaker
      var gasETBViewSettings = [];                      // save the user settings
      var gsETBMsgNoDoc   = { en: "No document active!",
                              de: "Kein dokument aktiv!"
      // alert ("ETBToggleViewsA really entered");
      SetUpMenu();
      function SetUpMenu() { // ==== Define the menu - even if not used =================================
      var sLabelEditing, sLabelPrinting, menuLocation, cmdDoc1, cmdDoc2;
        menuLocation = app.GetNamedMenu("ETBdummy");    // Required, even if not used
        cmdDoc1 = DefineCommand (1, "EditingDisplay",  "Document Editing Display [ETB]",  "\!qqe");
        cmdDoc2 = DefineCommand (2, "PrintingDisplay", "Document Printing Display [ETB]", "\!qqp");
        UpdateMenus();
      } // --- end SetUpMenu
      function Command(cmd) { // ==== Respond to menu/TB command ==================================
      alert ("ETBToggleViewsA command " + cmd + " entered");
          switch(cmd)  {
              case 1:
            SetEditingDisplay();
            break;
              case 2:
            SetPrintingDisplay();
            break;
      } // --- end Command
      function SetEditingDisplay () {
        alert ("SetEditingDisplay entered"); // of course there is more in here
      function SetPrintingDisplay () {
        alert ("SetPrintingDisplay entered"); // of course there is more in here
      But if I insert the following after line 11, then the script does not work anymore (it is loaded, but the Command function does not issue the alert etc.).
        sLabelEditing  = { en: "Document Editing Display [ETB]",
                           de: "Ansicht für Dokument Bearbeitung [ETB]" };
        sLabelPrinting = { en: "Document Printing Display [ETB]",
                           de: "Ansicht für Dokument Drucken [ETB]" };
      It doesn't work either if I place the following after line 06:
      var gsLabelEditing  = { en: "Document Editing Display [ETB]",
      var gsLabelPrinting = { en: "Document Printing Display [ETB]",
      I have similar constructs in various scripts with no problems so far.
      What is going on here?
        • 1. Re: FM-14: strange behaviour of SetUpMenu function
          K.Daube Level 2
          Since I had a problem with Windows update (see https://forums.adobe.com/thread/2346713) even this simple script does not work anymore - neither in FM-14.0.0.361, nor in update 1 nor in update 2.
          The menu set up function is run on start of FM, but the command function is not invoked - neither by shorcut nor by a button which specifies the command.
          This is a very stripped down version of the real script, which can be found on my website. It works if invoked in test mode - without menu set up.
          The absolute wierd thing is that all this has worked before the roblem with the Windows update (both build 361 and 406 - 415 was'n there at that time).
          All the other scripts I now have in the Enhanced Tool Bar work as intended. They are in the Startup folder and are invoked by button (Insert Symbol also by menu item):
          ETBinsertSymbol_en.jsx     has Notify function to bypass initial start, sets up menu items, used by button
          ETBSaveAsOld.jsx           with similar set up
          ETBtest.jsx            just a stub with similar setup
          • 2. Re: FM-14: strange behaviour of SetUpMenu function
            K.Daube Level 2
            Guess What?
            After carefully checking differences between a working stub and the full script I discovered the difference:
            The script must be coded in UTF-8 (it was Windows code page 1252).
            Wouldn't be a message about this possible?
            Klaus
