2 Replies Latest reply on May 13, 2017 5:49 PM by WobertC
    Lightroom CC 2015.10 & Windows 10
    Heirloom Bob Level 1
      Lightroom works fine, as near as I can tell but if I select Import, I get the "spinning circle" and nothing happens. I have not even inserted my SD at this point but I was able to read the SD card on this PC and transfer the contents to my HDD as an alternate method to import but the same results. Any thoughts?
        • 1. Re: Lightroom CC 2015.10 & Windows 10
          ManiacJoe Adobe Community Professional
          If you are saying that if your first launch the Import dialog without connecting your camera or SD card, I can see where some timeout value is going to be used when trying to find the missing connection.
          You should first connect your camera or insert the SD card into a card reader, then launch the Import dialog in LR.
          (A card reader is the better option.)
          • 2. Re: Lightroom CC 2015.10 & Windows 10
            WobertC Adobe Community Professional
            My Thoughts-
            Without the SD card inserted, Lightroom is searching your entire computer (thousands of files) to find everything to import, hence the "spinning wheel". It will stop eventually
            As ManiacJoe says- insert the card first, and use a card reader. Then select it in the 'Source' panel.
