I imported the first time linework from my ipad (Adobe Draw) to Adobe Illustrator. The process itself was absolutly easy.
Now I wanted to refine the linework, but instead of a single path per line I have the line represented as what I would name a "form" --> Outline and Inline per line
Can I create just a single path out of this mess of anchor points now? Else it would be much faster to redraw everything instead of cleaning it up...
Thank you,
Rabea
[Moved from Illustrator forum to Adobe Illustrator Draw (mobile app) by moderator]
I know your feelings about the millions of anchor point.
Take a look to this plug-in VectorFirstAid - Astute Graphics
It helps you to clean-up with the "Super Smart Remove" option.
For fine and more precise tuning you can use VectorScribe v3 - Astute Graphics
Best Regards
Where you have multiple closed paths of the same colour overlapping on import:
That's just how Adobe Draw works.
There's no one-click method to get single lines out if those shapes.
Thank you very much for your responses!
@Cari Jansen: The Pathfinder is nice to combine all those single shapes, but still the line is not a single path instead of a complex shape.
So I will follow Monika Gauses comment and just fix everything on my ipad until it´s ready to be published
Best Regards
