5 Replies Latest reply on May 15, 2017 5:52 AM by tpk1982
    Crop mark
    tpk1982 Level 4
      I am trying to modify the cropmark script as per my requirement. But little confused how to eliminate the cropmarks which comes in middle. Please suggest how to get rid this.
      Script:
      main();
      function main(){
        //Make certain that user interaction (display of dialogs, etc.) is turned on.
        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
        if (app.documents.length != 0){
        if (app.selection.length > 0){
        switch(app.selection[0].constructor.name){
        case "Rectangle":
        case "Oval":
        case "Polygon":
        case "GraphicLine":
        case "Group":
        case "TextFrame":
        case "Button":
        myDisplayDialog();
        break;
        default:
        alert("Please select a page item and try again.");
        break;
        else{
        alert("Please select an object and try again.");
        else{
        alert("Please open a document, select an object, and try again.");
      function myDisplayDialog(){
        var myDialog = app.dialogs.add({name:"CropMarks"});
        with(myDialog){
        with(dialogColumns.add()){
        var myCropMarksGroup = enablingGroups.add({staticLabel:"Crop Marks", checkedState:true});
        with (myCropMarksGroup){
        with(borderPanels.add()){
        staticTexts.add({staticLabel:"Options:"});
        with (dialogColumns.add()){
        staticTexts.add({staticLabel:"Length:"});
        staticTexts.add({staticLabel:"Offset:"});
        staticTexts.add({staticLabel:"Stroke Weight:"});
        var myCropMarkLengthField = measurementEditboxes.add({editValue:18, editUnits:MeasurementUnits.points});
        var myCropMarkOffsetField = measurementEditboxes.add({editValue:3, editUnits:MeasurementUnits.points});
        var myCropMarkWidthField = measurementEditboxes.add({editValue:.5, editUnits:MeasurementUnits.points});
        staticTexts.add({staticLabel:"Draw Marks Around:"});
        var myRangeButtons = radiobuttonGroups.add();
        with(myRangeButtons){
        radiobuttonControls.add({staticLabel:"Each Object", checkedState:true});
        radiobuttonControls.add({staticLabel:"Entire Selection"});
        var myReturn = myDialog.show();
        if (myReturn == true){
        //Get the values from the dialog box.
        var myDoCropMarks = myCropMarksGroup.checkedState;
        var myCropMarkLength = myCropMarkLengthField.editValue;
        var myCropMarkOffset = myCropMarkOffsetField.editValue;
        var myCropMarkWidth = myCropMarkWidthField.editValue;
        var myRange = myRangeButtons.selectedButton;
        myDialog.destroy();
        //"||" is logical OR in JavaScript.
        if ((myDoCropMarks != false) ){
        myDrawPrintersMarks(myRange, myDoCropMarks, myCropMarkLength, myCropMarkOffset, myCropMarkWidth);
        else{
        alert("No printers marks were selected.");
        else{
        myDialog.destroy();
      function myDrawPrintersMarks(myRange, myDoCropMarks, myCropMarkLength, myCropMarkOffset, myCropMarkWidth){
        var myBounds, myX1, myY1, myX2, myY2, myObject;
        var myDocument = app.activeDocument;
        var myOldRulerOrigin = myDocument.viewPreferences.rulerOrigin;
        myDocument.viewPreferences.rulerOrigin = RulerOrigin.spreadOrigin;
        //Save the current measurement units.
        var myOldXUnits = myDocument.viewPreferences.horizontalMeasurementUnits;
        var myOldYUnits = myDocument.viewPreferences.verticalMeasurementUnits;
        //Set the measurement units to points.
        myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
        myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
        //Create a layer to hold the printers marks (if it does not already exist).
        var myLayer = myDocument.layers.item("myCropMarks");
        try{
        myLayerName = myLayer.name;
        catch (myError){
        var myLayer = myDocument.layers.add({name:"myCropMarks"});
        //Get references to the Registration color and the None swatch.
        var myRegistrationColor = myDocument.colors.item("Registration");
        var myNoneSwatch = myDocument.swatches.item("None");
        //Process the objects in the selection.
        myBounds = myDocument.selection[0].visibleBounds;
        for(var myCounter = 0; myCounter < myDocument.selection.length; myCounter ++){
        myObject = myDocument.selection[myCounter];
        myBounds = myObject.visibleBounds;
        //Set up some initial bounding box values.
        if ((myRange != 0)&&(myCounter==0)){
        myX1 = myBounds[1];
        myY1 = myBounds[0];
        myX2 = myBounds[3];
        myY2 = myBounds[2];
        if(myRange == 0){
        if (myDoCropMarks == true){
        myDrawCropMarks (myBounds[1], myBounds[0], myBounds[3], myBounds[2], myCropMarkLength, myCropMarkOffset, myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        else{
        //Compare the bounds values to the stored bounds.
        //If a given bounds value is less than (for x1 and y1) or
        //greater than (for x2 and y2) the stored value,
        //then replace the stored value with the bounds value.
        if (myBounds[0] < myY1){
        myY1 = myBounds[0];
        if (myBounds[1] < myX1){
        myX1 = myBounds[1];
        if (myBounds[2] > myY2){
        myY2 = myBounds[2];
        if (myBounds[3] > myX2){
        myX2 = myBounds[3];
        if(myRange != 0){
        myDrawCropMarks (myX1, myY1, myX2, myY2, myCropMarkLength, myCropMarkOffset, myCropMarkWidth,myRegistrationColor, myNoneSwatch, myLayer);
        myDocument.viewPreferences.rulerOrigin = myOldRulerOrigin;
        //Set the measurement units back to their original state.
        myDocument.viewPreferences.horizontalMeasurementUnits = myOldXUnits;
        myDocument.viewPreferences.verticalMeasurementUnits = myOldYUnits;
      function myDrawCropMarks (myX1, myY1, myX2, myY2, myCropMarkLength, myCropMarkOffset, myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer){
        //Upper left crop mark pair.
        myDrawLine([myY1, myX1-myCropMarkOffset, myY1, myX1-(myCropMarkOffset + myCropMarkLength)], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        myDrawLine([myY1-myCropMarkOffset, myX1, myY1-(myCropMarkOffset+myCropMarkLength), myX1], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        //Lower left crop mark pair.
        myDrawLine([myY2, myX1-myCropMarkOffset, myY2, myX1-(myCropMarkOffset+myCropMarkLength)], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        myDrawLine([myY2+myCropMarkOffset, myX1, myY2+myCropMarkOffset+myCropMarkLength, myX1], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        //Upper right crop mark pair.
        myDrawLine([myY1, myX2+myCropMarkOffset, myY1, myX2+myCropMarkOffset+myCropMarkLength], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        myDrawLine([myY1-myCropMarkOffset, myX2, myY1-(myCropMarkOffset+myCropMarkLength), myX2], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        myDrawLine([myY2, myX2+myCropMarkOffset, myY2, myX2+myCropMarkOffset+myCropMarkLength], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
        myDrawLine([myY2+myCropMarkOffset, myX2, myY2+myCropMarkOffset+myCropMarkLength, myX2], myCropMarkWidth, myRegistrationColor, myNoneSwatch, myLayer);
      function myDrawLine(myBounds, myStrokeWeight, myRegistrationColor, myNoneSwatch, myLayer){
        app.activeWindow.activeSpread.graphicLines.add(myLayer, undefined, undefined,{strokeWeight:myStrokeWeight, fillColor:myNoneSwatch, strokeColor:myRegistrationColor, geometricBounds:myBounds})
      function myDrawTarget(myBounds, myStrokeWeight, myRegistrationColor, myNoneSwatch, myLayer){
        app.activeWindow.activeSpread.ovals.add(myLayer, undefined, undefined, {strokeWeight:myStrokeWeight, fillColor:myNoneSwatch, strokeColor:myRegistrationColor, geometricBounds:myBounds})
      Advance Thanks,
      K
