I am a Chinese user, English is relatively poor
see the picture
What the man said. Your workflow is simply crooked. The only format where AE can read custom channels is EXR. If you don't want/ can't re-render from your 3D app, then create an action or script in Photoshop to extract the info.
Mylenium
English: Duplicate your Depth and Object Buffer Channel separately to new ps documents, save them, and load them in Affer Effects. Then you'll be good to go.
中文:把你的深度和对象缓存通道分别复制到新的PS文档中,保存文件,导入到AE里就可以了。
嗯,我输出的是序列帧,如何能批量的复制出来
那你就不要把对象缓存和深度通道放到同一个PSD里了,导出成不同的文件
Mylenium
