I have an original RAW file in Lightroom which has a keyword applied to it. I now edit this image in Photoshop and save it as a .psd file. It correctly appears in Lightroom next to the parent RAW image. It also has the same keyword applied to it, i.e. it has inherited its parent's keyword. So far so good. HOWEVER, if I now select all images having that keyword applied to it, the edited .psd image is not selected, only the parent RAW file. BUT if I exit Lightroom and start it again, the .psd file now appears when I select that keyword.
Further information is that this only occurs if the keyword is a sub-category of a main keyword. For example, the main keyword is "Trossachs" and the sub-keyword is "Loch Lomond". The problem occurs if I edit an image with the keywords "Trossachs" - "Lock Lomond", but not if the image has two separate keywords which are independent,
This bug has been acknowledged by Adobe in the official feedback forum: Lightroom: keywords from Photoshop | Photoshop Family Customer Community . Please add your me-too vote and details of how this affects you to that bug report, which will make it a little more likely Adobe might fix it before the next ice age.
Several workarounds:
- Restart LR (which you know about, painful)
- Use the Text search box in the Library Filter bar (doesn't do exact search)
- Use the Any Tag plugin to search by one or
...Copy link to clipboard
- Use the Any Tag plugin to search by one or more keywords (costs money)
Thanks for your quick reply. Will wait for bug fix. Just further information. This only happens if you have a group of images selected via, say, a keyword. With the selection visible, choose an image, edit it in PS and save it. The resultant saved file will not appear in the selected group, even although it appears to have the same keyword. However if you select an image which is not part of a selected group and repeat, the keyword is present and the group can be re-selected including the edited image.
Please add your information and me-too vote to the bug report: Lightroom: keywords from Photoshop | Photoshop Family Customer Community . Adobe doesn't actively participate in this forum and won't see your posts here.
Ok. I have done that. Thanks
On Tue, May 16, 2017 at 4:25 PM, johnrellis <forums_noreply@adobe.com>
