3 Replies Latest reply on May 15, 2017 2:18 PM by rickmaldo
    Reduce colors available in CC
    rickmaldo
      I am doing an art project and I only have 47 colors available. Is there a way to tell PS/CC color palate which colors I have so it will change the picture I upload to reflect only those colors? My hope is that I will then see how the picture will look using only my 47 colors before I spend weeks creating it. Thank you!
        • 1. Re: Reduce colors available in CC
          Semaphoric Adobe Community Professional
          Start with a blank doc in 8-bit RGB mode. From the main menu, Image > Mode > Indexed Color, which will bring up this dialog:
          For Palette, choose Custom. You will see the Color Table dialog, and from there, you can add your colors. If you then save the palette as a .ACT file, you can then load it into your Swatches Panel. You will still be able to select any color for your Foreground and Background colors, but they will only paint in colors in the Color Table, which is why it;s a good idea to load them into your Swatches. You can also use the same Color Table in another doc by choosing that instead of Custom.
          If you alter the Color Table while you doc is open, it will update to show the changes, but they will not change in the Swatches Panel, unless you save the Color Table as a new .ACT file and load it into Swatches.
          When your project is complete, you can then convert it back to RGB.
          3 people found this helpful
          • 2. Re: Reduce colors available in CC
            Since the forum isn't letting me edit my post, I will add here that you could also convert any existing 8-bit RGB image to Indexed Color mode using your saved Color Table, and the RGB colors will be forced to the nearest color in your Color Table. However, the Layers must be flattened to do this. You can get around this by duplicating individual Layers into separate docs, converting them to Indexed and back to RGB there, and then duplicate them back to your original doc.
            2 people found this helpful
            • 3. Re: Reduce colors available in CC
              rickmaldo Level 1
              Thank you, Semaphoric.
