We use Adobe LCA in our project. we implement with Microsoft .NET C# language in our project.
My question is: i want to get the xml from the pdf document.
steps i perform is.
1)Get the current xml from Database.
2)Load the current xml into pdf form, by calling LCA webservice. Once the form is loaded, xml is updated/changed.
3)Get the new xml from Pdf.
We used webcontrol in c# to load the pdf.
how to convert the pdf to xml , we have the schema/class for it.
Could you please give the code in c#.
i believe we need to use some memory stream/ input stream/ byte array conversion.
