0 Replies Latest reply on May 16, 2017 2:31 PM by blumauricio
    Script to anchor all images in document to the closest paragraph.
    blumauricio
      Hello,
      I've asked this question in the general forum and they said that I should ask here.
      I need to export a document to ePub, and this document has at least 200 images.
      I know that I have to anchor them to the text because if not they will all be at the end of the ePub.
      I've found a script in a post 6 years ago that seems to be almost what I want.
      main();
      function main()
        var doc = app.activeDocument;
       var count=0;
       // loop through all pages
       for(i=0; i<doc.pages.length;i++)
              var page = doc.pages.item(i);
              if( page.textFrames.length<1) continue;
              var textFrame = page.textFrames.item(0);
              if(page.rectangles.length<1) continue;
              // loop through all rectangles in the page
              for(j=0;j<page.rectangles.length;j++)
                      var imageRect=page.rectangles[j];
                      if(imageRect.images.length<1) continue;
                      var myAnchoredFrame=anchorImage(doc, textFrame, imageRect);
                      var pos=[imageRect.geometricBounds[1],imageRect.geometricBounds[0]]
                      imageRect.remove();
                      j--;
                      textFrame.recompose();
                      var k=0;
                      // Reposition the anchored image. This is done repeatedly because the first call not moves the  frame to the correct position
                      do
                          myAnchoredFrame.move(pos);
                          k++;
                      while(k !=5);
                     count++;
      alert("Fixed "+count+" images");
      function anchorImage(doc, textFrame, imageRect)
              var myAnchoredFrame=CreateAnchor (doc, textFrame);
              var imBounds = imageRect.geometricBounds;
              var frBounds=textFrame.geometricBounds
              myAnchoredFrame.geometricBounds =  [imBounds[0]-frBounds[0], imBounds[1]-frBounds[1],
                                imBounds[2]-frBounds[0], imBounds[3]-frBounds[1]];
              // Copy image into the anchored frame. Didn't find a better way
              var imagePath=imageRect.images[0].itemLink.filePath;
              var image=imageRect.images[0];
              var filePath="D:\\im";
              image.exportFile(image.imageTypeName,filePath);
              myAnchoredFrame.place(File(filePath));
              // Resize image
              var newImBoundX=myAnchoredFrame.geometricBounds[1]-( imageRect.geometricBounds[1]-image.geometricBounds[1]);
              var newImBoundY=myAnchoredFrame.geometricBounds[0]-( imageRect.geometricBounds[0]-image.geometricBounds[0]);
              var newImBoundX1=newImBoundX+( image.geometricBounds[3]-image.geometricBounds[1]);
              var newImBoundY1=newImBoundY+( image.geometricBounds[2]-image.geometricBounds[0]);
              myAnchoredFrame.images[0].geometricBounds=[newImBoundY,newImBoundX,newImBoundY1,newImBoundX1];
              //Set textWrapPreferences of the images
              myAnchoredFrame.textWrapPreferences.textWrapMode=imageRect.textWrapPreferences.textWrapMode;
              myAnchoredFrame.textWrapPreferences.textWrapOffset =imageRect.textWrapPreferences.textWrapOffset ;
              return myAnchoredFrame;
      function CreateAnchor( doc, textFrame)
              var inPoint=textFrame.insertionPoints[0];
              var anchProps = doc.anchoredObjectDefaults.properties;
              var anchCont = anchProps.anchorContent;
              var myAO = inPoint.rectangles.add();
              // Make new object with correct default settings
              // Make new object right kind of object
              myAO.contentType =ContentType.graphicType;
              // Recompose parent story so geometricBounds make sense
              inPoint.parentStory.recompose();
              //save users measurement preferences
              userHoriz = doc.viewPreferences.horizontalMeasurementUnits;
              userVert = doc.viewPreferences.verticalMeasurementUnits;
              doc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
              doc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
              doc.viewPreferences.horizontalMeasurementUnits = userHoriz;
              doc.viewPreferences.verticalMeasurementUnits = userVert;
              myAO.applyObjectStyle(anchProps.anchoredObjectStyle);
              if (anchProps.anchorContent == ContentType.textType) {
                  try { // might be null
                  myAO.parentStory.appliedParagraphStyle = anchProps.anchoredParagraphStyle;
                  } catch (e) {}
              myAO.anchoredObjectSettings.properties = doc.anchoredObjectSettings.properties;
              myAO.anchoredObjectSettings.anchoredPosition=AnchorPosition.anchored;
              return myAO
      But this script is giving me the error "The specified object does not support the desired export format".
      Any ideas how to fix this?
