6 Replies Latest reply on May 17, 2017 7:56 AM by Bruce Bullis
    Javascript API for premiere pro
    nehrus86783659
      Where i can find the javascript API link for Premiere pro. I want to change the Lumetri color parameters like Exposure, Contrast, HIghlights, Shadows, Whites, Blacks and Saturation etc programmatically.
      Nehru
        • 1. Re: Javascript API for premiere pro
          andymees@aje Level 3
          Hey Nehru,
          As has been explained, there is no "JavaScript API" there is an ExtendScript API for interacting programmatically with Premiere, and the functionality for getting and setting keyframe values within Effect components is demonstrated in the PProPanel sample
          Javascript API to change Premiere Pro Lumetri color
          Basically, you have to navigate through the active sequence to select the target clip, within the clip to select the target component (eg Lumetri Effect), and within the component to select the target property (eg Exposure etc)
          so a particular property (eg Exposure, Contrast, Highlights ect) would be referenced using something like:
          myEffectProperty = app.project.activeSequence.videoTracks[i].clips[j].components[k].properties[l]
          where 'i' is the target track's index number (within the sequence)
          where 'j' is the target clip's index number (within the track)
          where 'k' is the component (effect) index number (within the clip)
          where 'l' is the property index number (within the effect)
          A quick scan of a targetted clip (using code derived directly from the PProPanel sample) reveals the following parameters (properties) for a Lumetri Color effect.
          var clipComponents = clip.components;
          if (clipComponents){
                for (var cc = 0; cc < clipComponents.numItems; ++cc) {
                      $.writeln('component ' + cc + ' = ' + clipComponents[cc].matchName + ' : ' + clipComponents[cc].displayName);
                      var componentProperties = clipComponents[cc].properties;
                      for (var cp = 0; cp < componentProperties.numItems; ++cp){
                            $.writeln('param ' + cp + ' = ' + componentProperties[cp].displayName);
          component 2 = AE.ADBE Lumetri : Lumetri Color
          param 0 = Blob
          param 1 =
          param 2 = Basic Correction
          param 3 =
          param 4 =
          param 5 =
          param 6 = Input LUT
          param 7 = HDR White
          param 8 = White Balance
          param 9 = WB Selector
          param 10 = Temperature
          param 11 = Tint
          param 12 =
          param 13 = Tone
          param 14 = Exposure
          param 15 = Contrast
          param 16 = Highlights
          param 17 = Shadows
          param 18 = Whites
          param 19 = Blacks
          param 20 = HDR Specular
          param 21 =
          param 22 =
          param 23 =
          param 24 = Saturation
          param 25 =
          param 26 = Creative
          param 27 =
          param 28 =
          param 29 =
          param 30 = Look
          param 31 = Intensity
          param 32 = Adjustments
          param 33 = Faded Film
          param 34 = Sharpen
          param 35 = Vibrance
          param 36 = Saturation
          param 37 =
          param 38 = Tint Balance
          param 39 =
          param 40 =
          param 41 = Curves
          param 42 =
          param 43 = RGB Curves
          param 44 = HDR Range
          param 45 =
          param 46 =
          param 47 = Hue Saturation Curves
          param 48 =
          param 49 =
          param 50 =
          param 51 = Color Wheels
          param 52 =
          param 53 = HDR White
          param 54 =
          param 55 =
          param 56 = HSL Secondary
          param 57 =
          param 58 = Key
          param 59 = Set color
          param 60 = Add color
          param 61 = Remove color
          param 62 =
          param 63 =
          param 64 =
          param 65 =
          param 66 =
          param 67 =
          param 68 =
          param 69 = Refine
          param 70 = Denoise
          param 71 = Blur
          param 72 = Blur
          param 73 = Correction
          param 74 =
          param 75 =
          param 76 = Temperature
          param 77 = Tint
          param 78 = Contrast
          param 79 = Sharpen
          param 80 = Saturation
          param 81 = Saturation
          param 82 =
          param 83 = Vignette
          param 84 =
          param 85 = Amount
          param 86 = Midpoint
          param 87 = Roundness
          param 88 = Feather
          param 89 =
          param 90 = SpeedGrade Custom
          param 91 = Custom Layer
          param 92 = unused
          param 93 = unused
          param 94 =
          param 95 =
          param 96 =
          param 97 = Embedded LUTs
          Cheers
          Andy
          • 2. Re: Javascript API for premiere pro
            sberic Level 3
            The four best resources I'm aware of for exploring the Premiere Pro ExtendScript API follow:
            1. The ExtendScript Toolkit's Object Model Viewer - A built-in documentation browser that displays some of the available application APIs. Unfortunately, it's a bit out of date and does not contain any documentation for Components.
            2. The PProPanel api_doc.html page - This is the only resource I'm aware of that provides actual documentation for some of the Premiere Pro ExtendScript APIs. Unfortunately, it is an html page and is best viewed by cloning the repository locally and opening the page in a browser.
            3. The PProPanel Premiere.jsx script - Bruce Bullis has consistently directed users to reference this sample code for insight into the Premiere Pro API. Advancements have been made (see #2 above), but, sadly, the most common suggestion is to reference this document.
            4. The Property Explorer Addon - A free utility provided by a community member that allows you to investigate APIs (properties and methods) at runtime from within the running application (e.g. Premiere Pro). As this utility uses a combination of ExtendScript Reflection and basic JavaScript property enumeration at runtime, it is capable of revealing APIs that are not documented in any of the aforementioned resources. Note that it may require special installation.
            I hope this is helpful for future developers similarly struggling to find their bearing in this development environment!
            • 3. Re: Javascript API for premiere pro
              Bruce Bullis Adobe Employee
              One new, additional resource = Bryson Michael has put together an online API reference! http://www.brysonmichael.com/premiereapi-home
              • 4. Re: Javascript API for premiere pro
                sberic Level 3
                Addendum #1 - QE DOM
                I should quickly add that certain APIs are 100% hidden from all of the resources I mentioned above. One major hole in the documentation is the QE DOM. According to Bruce Bullis, the QE DOM is "officially unsupported, and not recommended".
                That said, certain important functionality is simply impossible without it. While at odds with the above statement, the much recommended official Premiere.jsx file makes use of it 6 times (at time of writing). In short, to make use of it, you must first run the following hidden API:
                app.enableQE();
                Running this function will insert a global qe object into the ExtendScript context, providing you with access to a large list of features (some of which are used in the Premiere.jsx file). The inserted object is a raw JavaScript (or ExtendScript) object, so it does not have a "Class" type associated with it.
                Addendum #2 - Accessing the Object Model Viewer
                I only just found this link, but I recommend checking it out for learning how to access the ExtendScript Toolkit's Object Model Viewer (#1 in the resources previously mentioned).
                • 5. Re: Javascript API for premiere pro
                  sberic Level 3
                  Where did Bryson get the documentation? Some APIs listed there are undocumented in the resources I previously mentioned while others that are documented (e.g. in api_doc.html) don't have any descriptive content.
                  • 6. Re: Javascript API for premiere pro
                    Personal experience? He didn't have access to anything that isn't already available.
                    Broadly: Yes, we realize that more documentation could make getting started, and helping yourself, easier. We stopped counting "PPro panels in active use, every day" once we got past 250; we don't think the lack of further documentation is preventing necessary integrations.
                    Until recently, we have focused on working code examples, over documentation work. That has changed.
                    Actually, for many development tasks, we've been told that screencasts walking through common tasks are more useful, than written instructions for moving doing the same things. My team and I are working on screencasts, and development heuristics (how to address commonly-requested tasks).
                    In the mean time, continue to feel free to ask us anything. We want all integrations to be successful.
