Hello,
we got a problem managing/editing texts in Incopy over different fileshares on a linux server.
We are using Incopy 2017 and Indesign 2017.
The Problem:
Texts from Volume 1 will be connected to a Incopy file on Volume 3.
The text can be displayed, but not managed.If you click on the text, we get the following message: Textfile could not be opened.
If the textfile is located on the same Volume the textfile could be managed.
Any ideas?
This should be the answer?
Adobe doesn´t use UNC-paths?
I think you’ve pretty much already answered your own question.
Hi Sebastian,
Would suggest you to use the same volume. It seems to be an issue with the path/permission. I believe that's what Bob meant. You can check this link for the detail workflow: Understand a basic managed-file workflow in InDesign
Regards,
Om
