• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Should I check republish?
Explorer ,
Oct 09, 2008 Oct 09, 2008
I' ve been publishing my project to the network each evening and have not used any defined conditional build tags yet. When, at last, I do should I check the Republish All check box? The reason I ask is because I'm wondering what happens to all the files that had previously been published to the network folder. I hope I'm making sense.
Views
369
Translate
Translate
Report
Report
Community guidelines
community guidelines
Deleted User
Publishing takes files that have changed (newer time stamp) and copies them to the destination folder (in this case, your network folder).
Applying conditional tags to topics (at either the topic or content level) is a change to the topics, and publishing without the Republish All option should copy those changed files to the network folder. The copied (newer) files overwrite files of the same name in the network folder.
Any files you didn't change will not be overwritten on the network unles...
Votes
Translate
Translate
Guest
Any files you didn't change will not be overwritten on the network unless you do "Republish All."
--Ben
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 10, 2008 Oct 10, 2008
So what type of scenario would prompt you to check the 'Republish all' box. It is my understanding from your response that I do not need to check republish all when I add conditional build tags because the corresponding topic, being changed, will update accordingly in the network folder. Am I following?
Votes
Translate
Translate
Report
Report
Guest
Correct.
I imagine that one scenario would be that some problem begins occurring with the files on the network and you're not able to figure out what's wrong. Republish All would allow you to overwrite all files and thereby refresh the help in its entirety.
Votes
Translate
Translate
Report
Report
LEGEND ,
Oct 11, 2008 Oct 11, 2008
LATEST
Hi Renee
Ben's reply is a good one. But just in case that you mentally didn't connect with that situation, I'll toss out another where you might want to check the Republish All option.
Back when I was working in the corporate world, on more than one occasion I arrived to work on a Monday to find a nice little note from my network admins. Generally it would go a bit like this:
Hi folks,
Unfortunately, during the process of (insert situation here - Upgrade, Backup, Migration) of the servers over the weekend, things went dreadfully wrong. We believe we have restored all the files properly from our backups, but please double-check your links to ensure all is well.
So, in this situation, do you think I'm going to waste my time "checking links"? Heck no! I'll be checking that Republish All option and be done with it.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
