I am trying to reduce 18 Mb file to 4 Mb or less. So far I got 4.2 Mb. I also decided to remove a background, but instead of decreasing the size of the file started to grow. What's that?
How are you presently creating the PDF and from which application?
You can use Adobe Acrobat DC to reduce the size of the PDF after you've created it:
One additional note:
If you work for a government agency and have created an Accessible PDF, please keep in mind that the additional tagging structure adds to the file size of the PDFs. Also when using the Optimizer ensure you don't remove any elements required for Accessibility.
Use the Save As command and save the file under a new name. It will trigger
an optimization process that should decrease the file-size, if possible.
On Thu, May 18, 2017 at 12:28 AM, alexanders89992161 <
