Hello everyone. I have already asked about changing colors of guides -->Is there a way to have multiple color guides? <-- but I am having trouble adapting it to this script. I have been using AddGuides.jsx for a while now and i have a few changes that i'm trying to do but cant seem to make them work. I'm trying to get my radiobuttons i created to *when selected* change the default color of the guides to Red, Blue, black etc.. I added lines 89-96 + 198-209 so the buttons are showing up i'm just not sure how to get them to acutally change colors. Now i have added Lines 403 and 410 and that will change the color but i'm wanting the color to only change if my radiobuttons are selected. And right now i have lines 403+410 on 5 different scripts (with different RGB values on each). I then merged these scripts into another scriptUI i made and i can select the colors from there. But his is an extra step i'm trying to get rid of. I would like it all to be in this one script.
//AddGuides.jsx
//An InDesign JavaScript
@@@BUILDINFO@@@ "AddGuides.jsx" 3.0.0.0 14 December 2009
//This script draws guides around the selected object or objects.
//Choose Visible Bounds to consider the stroke weight of the paths when placing the guides,
//or choose Geometric Bounds to ignore the stroke weight when placing the guides
//Choose Each Item to position the guides around individual items in the selection,
//or Entire Selection to position the guides around the selection as a whole.
//This script also includes an alternative dialog box for the script. This dialog was
//created using the ExtendScript ScriptUI component. ScriptUI lacks some of the useful
//controls that the InDesign dialog object offers, but it can be used to create interactive
//dialog boxes and panels.
//For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
//Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com.
main();
function main(){
//Make certain that user interaction (display of dialogs, etc.) is turned on.
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
var myObjectList = new Array;
if (app.documents.length != 0){
if (app.selection.length != 0){
for(var myCounter = 0;myCounter < app.selection.length; myCounter++){
switch (app.selection[myCounter].constructor.name){
case "Rectangle":
case "Oval":
case "Polygon":
case "TextFrame":
case "Group":
case "Button":
case "GraphicLine":
myObjectList.push(app.selection[myCounter]);
break;
if (myObjectList.length != 0){
var myOldXUnits = app.documents.item(0).viewPreferences.horizontalMeasurementUnits;
var myOldYUnits = app.documents.item(0).viewPreferences.verticalMeasurementUnits;
app.documents.item(0).viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
app.documents.item(0).viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
myDisplayDialog(myObjectList);
//Comment out the previous line and uncomment the following line to use a ScriptUI dialog.
//myDisplayScriptUIDialog(myObjectList);
app.documents.item(0).viewPreferences.horizontalMeasurementUnits = myOldXUnits;
app.documents.item(0).viewPreferences.verticalMeasurementUnits = myOldYUnits;
else{
alert ("Please select a page item and try again.");
else{
alert ("Please select an object and try again.");
else{
alert ("Please open a document, select an object, and try again.");
function myDisplayDialog(myObjectList){
var myRangeButtons, myBasedOnButtons;
var myLabelWidth = 100;
var myDialog = app.dialogs.add({name:"AddGuides"});
with(myDialog){
with(dialogColumns.add()){
with(borderPanels.add()){
staticTexts.add({staticLabel:"Add Guides At:"});
var myTopCheckbox = checkboxControls.add({staticLabel:"&Top", checkedState:true});
var myLeftCheckbox = checkboxControls.add({staticLabel:"&Left", checkedState:true});
var myBottomCheckbox = checkboxControls.add({staticLabel:"&Bottom", checkedState:true});
var myRightCheckbox = checkboxControls.add({staticLabel:"&Right", checkedState:true});
var myXCenterCheckbox = checkboxControls.add({staticLabel:"&Horizontal Center", checkedState:false});
var myYCenterCheckbox = checkboxControls.add({staticLabel:"&Vertical Center", checkedState:false});
var myXPointCheckbox = checkboxControls.add({staticLabel:"Path Point Hori&zontal Anchor", checkedState:false});
var myYPointCheckbox = checkboxControls.add({staticLabel:"Path Point Verti&cal Anchor", checkedState:false});
staticTexts.add({staticLabel:"Add Guides Around:"});
with(myRangeButtons = radiobuttonGroups.add()){
radiobuttonControls.add({staticLabel:"Each &Object", checkedState:true, minWidth:156});
radiobuttonControls.add({staticLabel:"Entire &Selection"});
staticTexts.add({staticLabel:"Guide Color:"});
radiobuttonControls.add({staticLabel:"Red", checkedState:false, minWidth:156});
radiobuttonControls.add({staticLabel:"Blue"});
radiobuttonControls.add({staticLabel:"Black"});
with(dialogRows.add()){
staticTexts.add({staticLabel:"Guides Based On:"});
with(myBasedOnButtons = radiobuttonGroups.add()){
radiobuttonControls.add({staticLabel:"&Geometric Bounds", checkedState:true, minWidth:160});
radiobuttonControls.add({staticLabel:"V&isible Bounds"});
staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
var myXOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
var myYOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
myReturn = myDialog.show();
if (myReturn == true){
//Get control values from the dialog box.
var myTop = myTopCheckbox.checkedState;
var myLeft = myLeftCheckbox.checkedState;
var myBottom = myBottomCheckbox.checkedState;
var myRight = myRightCheckbox.checkedState;
var myXCenter = myXCenterCheckbox.checkedState;
var myYCenter = myYCenterCheckbox.checkedState;
var myXPoint = myXPointCheckbox.checkedState;
var myYPoint = myYPointCheckbox.checkedState;
var myBasedOn = myBasedOnButtons.selectedButton;
var myRange = myRangeButtons.selectedButton;
var myXOffset = myXOffsetField.editValue;
var myYOffset = myYOffsetField.editValue;
//Remove the dialog box from memory.
myDialog.destroy();
if(myTop+myLeft+myBottom+myRight+myXCenter+myYCenter+myXPoint+myYPoint !=0){
myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList);
else{
alert("No guides were specified.");
else{
myDialog.destroy();
//ScriptUI version of the above dialog box.
function myDisplayScriptUIDialog(myObjectList){
var myBasedOn, myRange;
var myDialog = new Window('dialog', 'AddGuides');
with(myDialog){
alignChildren = 'fill';
var myGuideTypesPanel = add('panel', undefined, "Add Guides At:");
with(myGuideTypesPanel){
orientation = 'column';
alignChildren = 'left';
margins = [12, 16, 12, 6];
spacing = 4;
myDialog.myTopCheckbox = add('checkbox', undefined, "Top");
myDialog.myTopCheckbox.value = true;
myDialog.myLeftCheckbox = add('checkbox', undefined, "Left");
myDialog.myLeftCheckbox.value = true;
myDialog.myBottomCheckbox = add('checkbox', undefined, "Bottom");
myDialog.myBottomCheckbox.value = true;
myDialog.myRightCheckbox = add('checkbox', undefined, "Right");
myDialog.myRightCheckbox.value = true;
myDialog.myXCenterCheckbox = add('checkbox', undefined, "Horizontal Center");
myDialog.myXCenterCheckbox.value = true;
myDialog.myYCenterCheckbox = add('checkbox', undefined, "Vertical Center");
myDialog.myYCenterCheckbox.value = true;
myDialog.myXPointCheckbox = add('checkbox', undefined, "Path Point Horizontal Anchor");
myDialog.myXPointCheckbox.value = true;
myDialog.myYPointCheckbox = add('checkbox', undefined, "Path Point Vertical Anchor");
myDialog.myYPointCheckbox.value = true;
var myGuideLocationPanel = add('panel', undefined, "Add Guides Around:");
with(myGuideLocationPanel){
margins = [12, 14, 12, 6];
spacing = 4;
myDialog.myEachObjectRadioButton = add('radiobutton', undefined, "Each Object");
myDialog.myEachObjectRadioButton.value = true;
myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Entire Selection");
var myColorGuideLocationPanel = add('panel', undefined, "Guide Colors:");
with(myColorGuideLocationPanel){
guideColor = [255,255,150] ;
spacing = 4;
myDialog.myEachObjectRadioButton = add('radiobutton', undefined, "Red");
myDialog.myEachObjectRadioButton.value = false;
myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Blue");
myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Black");
var myGuidesBasedOnPanel = add('panel', undefined, "Add Guides Based On:");
with(myGuidesBasedOnPanel){
spacing = 4;
myDialog.myGeometricBoundsRadioButton = add('radiobutton', undefined, "Geometric Bounds");
myDialog.myGeometricBoundsRadioButton.value = true;
myDialog.myVisibleBoundsRadioButton = add('radiobutton', undefined, "Visible Bounds");
with(add('group')){
orientation = 'row';
alignChildren = 'center';
spacing = 2;
with(add('group')){
alignChildren = 'right';
var myXOffsetLabel = add('statictext', undefined, "Horizontal Offset:");
var myYOffsetLabel = add('statictext', undefined, "Vertical Offset:");
with(add('group')){
myDialog.myXOffsetField = add('edittext', undefined, "0", {enterKeySignalsOnChange:false});
myDialog.myXOffsetField.characters = 7;
myDialog.myXOffsetField.justify = "right";
myXOffsetField.onChange = function(){
if(myValidateNumber(myXOffsetField.text)==false){
alert("Invalid numeric entry!");
myDialog.myXOffsetField.text = "0";
myDialog.myYOffsetField = add('edittext', undefined, "0");
myDialog.myYOffsetField.justify = "right";
myDialog.myYOffsetField.characters = 7;
myYOffsetField.onChange = function(){
if(myValidateNumber(myYOffsetField.text)==false){
myDialog.myYOffsetField.text = "0";
with(add('group')){
add('statictext', undefined, "points");
with(add('group')){
alignment = 'right';
myDialog.myCloseButton = add('button', undefined, "Close", {name:'cancel'});
myDialog.myCloseButton.onClick = function(){myDialog.close()};
myDialog.myOKButton = add('button', undefined, "OK", {name:'ok'});
var myReturn = myDialog.show();
with(myDialog){
var myTop = myTopCheckbox.value;
var myLeft = myLeftCheckbox.value;
var myBottom = myBottomCheckbox.value;
var myRight = myRightCheckbox.value;
var myXCenter = myXCenterCheckbox.value;
var myYCenter = myYCenterCheckbox.value;
var myXPoint = myXPointCheckbox.value;
var myYPoint = myYPointCheckbox.value;
var myXOffset = parseFloat(myXOffsetField.text);
var myYOffset = parseFloat(myYOffsetField.text);
if(myGeometricBoundsRadioButton.value == true){
myBasedOn = 0;
else{
myBasedOn = 1;
if(myEachObjectRadioButton.value == true){
myRange = 0;
else{
myRange = 1;
myDialog.close();
else{
else{
myDialog.close();
function myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList){
var myLayer, myCounter;
var myOldRulerOrigin = app.activeDocument.viewPreferences.rulerOrigin;
app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.spineOrigin;
//Create a layer to hold the printers marks (if it does not already exist).
myLayer = app.activeDocument.layers.item("Guides");
try{
myLayerName = myLayer.name;
catch (myError){
myLayer = app.activeDocument.layers.add({name:"Guides"});
//Process the objects in the selection.
for(myCounter = 0; myCounter < myObjectList.length; myCounter ++){
var myObject = myObjectList[myCounter];
if (myBasedOn == 0){
myBounds = myObject.geometricBounds;
else{
myBounds = myObject.visibleBounds;
//Draw guides at path point locations, if necessary.
if ((myXPoint == true)||(myYPoint == true)){
myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint);
//Set up some initial bounding box values.
if ((myRange != 0)&&(myCounter==0)){
myX1 = myBounds[1];
myY1 = myBounds[0];
myX2 = myBounds[3];
myY2 = myBounds[2];
if(myRange == 0){
myDrawGuides (myBounds[1], myBounds[0], myBounds[3], myBounds[2], myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
else{
//Compare the bounds values to the stored bounds.
//If a given bounds value is less than (for x1 and y1) or
//greater than (for x2 and y2) the stored value,
//then replace the stored value with the bounds value.
if (myBounds[0] < myY1){
myY1 = myBounds[0];
if (myBounds[1] < myX1){
myX1 = myBounds[1];
if (myBounds[2] > myY2){
myY2 = myBounds[2];
if (myBounds[3] > myX2){
myX2 = myBounds[3];
if(myRange != 0){
myDrawGuides (myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
app.activeDocument.viewPreferences.rulerOrigin = myOldRulerOrigin;
function myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint){
for(var myPathCounter = 0; myPathCounter < myObject.paths.length; myPathCounter++){
for(var myPointCounter = 0; myPointCounter < myObject.paths.item(myPathCounter).pathPoints.length; myPointCounter ++){
if(myXPoint==true){
myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[0], 1);
if(myYPoint==true){
myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[1], 0);
function myDrawGuides(myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset){
if (myTop == true){
myDrawGuide(myY1 - myYOffset, 0);
if (myLeft == true){
myDrawGuide(myX1 - myXOffset, 1);
if (myBottom == true){
myDrawGuide(myY2 + myYOffset, 0);
if (myRight == true){
myDrawGuide(myX2 + myXOffset, 1);
if (myXCenter == true){
myDrawGuide(myX1+((myX2-myX1)/2), 1);
if (myYCenter == true){
myDrawGuide(myY1+((myY2-myY1)/2), 0);
function myDrawGuide(myGuideLocation, myGuideOrientation){
var myLayer = app.activeDocument.layers.item("Guides");
with(app.activeWindow.activeSpread){
if(myGuideOrientation == 0){
with (guides.add(myLayer, undefined, undefined)){
orientation=HorizontalOrVertical.horizontal;
// guideColor = [255,0,0] ;
location=myGuideLocation;
else{
orientation=HorizontalOrVertical.vertical;
function myValidateNumber(myString){
var myRegExp = /(^-?\d\d*\.\d*$)|(^-?\d\d*$)|(^-?\.\d\d*$)/;
return myRegExp.test(myString);
I also tried to add this to lines 415-433 but it didn't change the color. and this is not specific to each seperate Radiobutton.
function myColorDrawGuide(myColorGuideLocation, myColorGuideOrientation){
else{
Do you want this effect?
(你是想要這個效果嗎?)
...//AddGuides.jsx
The Script in the above links is below:
- var doc = app.documents[0];
- app.documents[0].spreads[0].guides.add
- guideColor : [255,0,0] ,
- guideType : GuideTypeOptions.RULER ,
- orientation : HorizontalOrVertical.VERTICAL ,
- fitToPage : true ,
- itemLayer : doc.layers[0]
I Should point out i am only interested in guideColor I may add Fit to page later but Color is the important one.
(你是想要這個效果嗎?)
//AddGuides.jsx
main();
function main(){
case "Rectangle":
case "Oval":
case "Polygon":
case "TextFrame":
case "Group":
case "Button":
case "GraphicLine":
break;
else{
else{
else{
with(myDialog){
with(myColorRangeButtons = radiobuttonGroups.add()){
radiobuttonControls.add({staticLabel:"Red", checkedState:true, minWidth:156});
var myColorRange = myColorRangeButtons.selectedButton;
switch (myColorRange){
case 0:
MY_GUIDE_COLOR = [255, 0, 0]
break;
case 1:
MY_GUIDE_COLOR = [0, 0, 255]
break;
case 2:
MY_GUIDE_COLOR = [0, 0, 0]
break;
myDialog.destroy();
else{
else{
myDialog.destroy();
with(myDialog){
spacing = 4;
spacing = 4;
spacing = 4;
spacing = 4;
with(add('group')){
spacing = 2;
with(add('group')){
with(add('group')){
with(add('group')){
with(add('group')){
with(myDialog){
myBasedOn = 0;
else{
myBasedOn = 1;
myRange = 0;
else{
myRange = 1;
myDialog.close();
else{
else{
myDialog.close();
try{
catch (myError){
else{
myX1 = myBounds[1];
myY1 = myBounds[0];
myX2 = myBounds[3];
myY2 = myBounds[2];
if(myRange == 0){
else{
myY1 = myBounds[0];
myX1 = myBounds[1];
myY2 = myBounds[2];
myX2 = myBounds[3];
if(myRange != 0){
if(myXPoint==true){
if(myYPoint==true){
if (myTop == true){
guideColor = MY_GUIDE_COLOR;
else{
Thank you so much this is exactly what i've been trying to do for the past 2 days. I'm gonna study this script so I can see what you did to make it work and what i was doing wrong.
I was on the right track yesterday. I had the radio button control in the wrong place i had it in "SCRIPT UI" portion i needed to move it up. again. Thank you
