2 Replies Latest reply on May 19, 2017 8:14 AM by thomas olbrich
    can not "save as" in same folder - error "file protected ... or in use"
    thomas olbrich
      Since a while (might be since update to macOS Sierra 10.12.x) I can not save a PDF with a different name into the same folder. An error message appears:
      "The file is either write protected or in use by another user. Save the file under another name or in a different folder"
      (original message in German)
      I can save in a different folder. When I open that new file, do a change and "save as" with a new, third name the same error appears again. I can save as in any other, even in the folder of the first original PDF. So its not a matter of folder rights.
      When I open a PDF and want to optimize it than nothing happens when I simply save. I have to "save as" and select a different location.
      Acrobat 10.1.16  |  macOS 10.12.3
      Any hints appreciated!
        • 1. Re: can not "save as" in same folder - error "file protected ... or in use"
          Cari Jansen Adobe Community Professional
          I've seen this issue in the past when the following occurred:
          • If you select the file in the Finder and double click it, it remains 'active' somehow.
          • Then issues with saving might occur.
          • I've seen that happen on Windows and Mac OS
          Have not seen this issue for a while, but can you try the following:
          1. Don't select any of the PDFs in the folder.
          2. Launch Acrobat, then choose File > Open and navigate to the folder that contains the PDF file.
          3. Make the change, and then try a Save As, and see if it works?
          If that doesn't work I'd look at testing and possibly repairing the file permissions on your system.
          • 2. Re: can not "save as" in same folder - error "file protected ... or in use"
            thomas olbrich Level 1
            Unfortunately none of the hints do help in this case – my pdfs just behave different to your experience. Also, I have this issues in the last weeks, or 2-3 month only, whereas you did not have them recently but more time ago. Nevertheless I did the open-method-tests:
            My results with the 2 methods to open a PDF before "save as" with a new filename:
            It works fine unless a PDF has been opened before – independent of the way to open it.
            If I rename a PDF in the finder and open it 1st time in Acrobat then I am able to save as into the same folder.
            As soon I open this PDF a second time – either from finder or from Acrobats open or recent files menu – then I am not able to save as in the same folder and I get the error mentioned above.
            I can choose any other folder (even within such a problematic folder) to save as – and, also, I can switch between two folders to continue a save as several times for testing. But I HAVE TO switch to be allowed to save as. That means very clear it is not a problem of rights on system level but must be a misinterpretation of Acrobat.
            This issue also appears if I quit and restart Acrobat in between. That might mean the problem occurs as soon Acrobat has a file name and storage place in its recent files list.
