This is only a problem on an andriod device in chrome.
ok I made a long scrolling website design and scrolling up or down works great but if I click on an anchor that takes me down the page and then I manually scroll back to the top, if i scroll to far past the top of the page chrome does this "pull to refresh" function. This wouldn't be a problem if it just refreshed at the top of the page but its refreshing back to the last anchor I used at the bottom of the page. The end result is if i scroll past the top of the page accidentally it jumps down to the last anchor I used.
I found this article but if i knew how to write code i probably wouldn't be using muse.
html - Disabling android's chrome pull-down-to-refresh feature - Stack Overflow
at the bottom of the article is this code
$("html").css({
"touch-action": "pan-down"
Where does this code go? in a javascript file ? or a css file?
you can have it in an iframe, page or site... most designs work best with a page
I put it in there but it's not working. isn't code with a $ go into a javascript file? this put it in the index.html head.
your question was where does this code go... not would it work in your site.
no a $ tells the browser that this IS code... it is added to whatever javascript the browser is using but it not placed inside it and some browsers will ignore code addons because they are not trusted
the code says add this (css codes) when this (html = page) is rendored;
moving forward, there is a code sub-group in the Dreamwever forum and I recommend you ask your code questions there as those guys have forgotten more about javascript etc than most people ever learn
