Hi, I'm creating an e-learning course (a responsive project) in Captivate 2017 and I have a slide where an image flies in from the top left. I used the animation preset "Fly in From Top Left" to achieve this and when I play the slide within Captivate Software it plays fine, the animation is spread across the entire duration of the slide. However, when I preview or publish the project, the animation gets about half-way through and then stops, leaving my graphic about half-way off the slide.
Is there something I am missing?
Here is an image of my timeline. The graphic with the animation is "Image_2" and the animation is underneath it. It spans across the entire timeline so I am confused as to why it doesn't play entirely upon being previewed or published.
Of course it stops at the pausing point of all your interactive objects, I see 8 in that screenshot. That pausing point is at 1,5secs while the 'Fly in' is timed at 3 secs, so only half of the animation will be done before the playhead stops.
Understanding the timeline, is THE most important basic skill for any Captivate user. I did write a sequence of 5 articles, trying to clarify. Look at:
Challenges for Starters - Captivate blog
Pausing Captivate's Timeline - Captivate blog
Solution: either you
...Copy link to clipboard
Solution: either you shorten the duration of the effect (can be done by dragging its timeline or in the TIming panel) or you delay the pausing points (do you need all of them?) for the interactive objects. That can be done by dragging the pausing points or in the Timing panel all at once. Be careful: keep them at identical times to avoid other issues. Maybe you'll need a little bit of both: shorten duration effect and delaying the pausing point (not totally at the end but about 0,2secs from end timeline slide).
Thank you!! I figured it was something simple like that.
