1 Reply Latest reply on May 21, 2017 5:14 AM by e.d.
    Video Usage access for Footage
    jportell25
      Within the Project Panel's Metadata Display, I have been using the "Video Usage" feature to tell if any of my clips have been used.
      Is there a way to access this info? I would like to combine all unused footage into a bin at the end of a project?
        • 1. Re: Video Usage access for Footage
          e.d. Level 3
          There is...
          app.project.rootItem[index].getProjectMetadata();
          This should give you an XML object with all of the metadata being presented in the metadata panel of Premiere.
          Inside there is a child "<premierePrivateProjectMetaData:Column.Intrinsic.VideoUsage>".
          It seems it is a string though, but this you can split as well by above string to give you the number.
          You can also wrap it into an XML object
          var theXML = new XML(app.project.rootItem.children[2].getProjectMetadata());
          and eventually you will find the correct child.
          var usageCount = theXML.child(0).child(0).child('premierePrivateProjectMetaData:Column.Intrinsic.VideoUsage');
          Depends on what you're trying to achieve.
          3 people found this helpful
