21 Replies Latest reply on May 20, 2017 10:55 AM by kglad
    Can't remove Event Listener?
    Focusfilm.at Level 1
      hi, please help. Why won't my Event Listener get removed and the function stopped from executing?
      function energy_dec(e=null)
        if (Sl02_Target_Percent > 30)
        Sl02_Target_Percent--
        if (EL_dec_present == false)
        t.addEventListener(TimerEvent.TIMER,energy_dec);
        EL_dec_present = true
        trace("EL_dec ADDED")
        else
        t.stop()
        t.removeEventListener(TimerEvent.TIMER,energy_dec);
        EL_dec_present = false
        trace("EL_dec REMOVED")
      energy_dec();
      Thanks...
        • 1. Re: Can't remove Event Listener?
          put a trace outside that function body.  does that one execute more than once?
          p.s. if you want your timer to only execute once, why don't you set it up to do just that?
          var t:Timer=new Timer(whatever,1);
          • 2. Re: Can't remove Event Listener?
            hi kglad, thanks for your quick reply...
            Yeah, the function gets executed once every time the animation plays from the beginning , thats not the problem. Problem is that it executes every time the timer triggers (in my case two times a second...), even after i try to stop the timer ind remove the EL...
            • 3. Re: Can't remove Event Listener?
              @ps: i fear thats not an option because if energy is currently 50, the timer has to execute 20 times to get to 30, when energy is 70 it has to execute 40 times. i guess i coul calculate a var that says how often the timer has to execute and put that in the timer. I am just curious, why my code does not work...the else condition gets triggered(twice a second) once energy is below 30 but the EL does not get removed and the timer does not stop...??
              • 4. Re: Can't remove Event Listener?
                because of the lack of formatting i failed to see those nested if-statements.  but now that i look more closely, i don't even see where your timer would start.
                • 5. Re: Can't remove Event Listener?
                  sorry for lack of formatting...
                  i start the timer once in my "initialiser" function at the beginning of the code. It does only execute once, not every time the animation loops...
                  • 6. Re: Can't remove Event Listener?
                    the code you showed makes no sense.  the code you're not showing (when combined with the code you are showing) might make sense but i can't determine that.  ie, show the relevant code.
                    • 7. Re: Can't remove Event Listener?
                      My whole code is pretty long and messy by now, but i will try to extract the relevant parts:
                      import flash.events.Event;
                      var initializer;
                      var Sl02_Target_Percent;
                      var tSpeed:uint = 100;
                      var t:Timer = new Timer(tSpeed,0)
                      var EL_dec_present:Boolean;
                      //Initializer START____________________________________________
                      function Intialize()
                        if(initializer == false)
                        trace("Initializer DONT fire");
                        else
                        trace("Initializer FIRE");
                        Sl02_Target_Percent =80;
                        t.start();
                        EL_dec_present = false;
                        initializer=false;
                      Intialize()
                      // Initializer END___________________________________________
                      // Function Energy Decrease
                        trace ("Sl02_Target_Percent = " + Sl02_Target_Percent)
                        else
                        t.stop()
                      energy_dec();
                      SORRY, if my code is messy and does not make sense, i am a novice, this is my very first proj in Flash, but i am really trying to learn...
                      • 8. Re: Can't remove Event Listener?
                        is that code in a frame that plays more than once?  if yes, that's a problem.
                        if not, add a trace statement outside the function bodies and show the trace output
                        • 9. Re: Can't remove Event Listener?
                          The code is on the first frame of a layer called "Actions" on the main stage. The Animation is 100 frames long and loops indefinitely. Could you pls elaborate why this is a problem when i try to remove an EL or stop a timer?
                          i was thinking that i have the "Initialize" function for things that only have to get executed once, not every time the animation loops
                          • 10. Re: Can't remove Event Listener?
                            initialize() and energy_dec() are called each time you enter the frame that contains that code.
                            to prevent that use:
                            var initialize_called:Boolean;
                            var energy_dec_called:Boolean;
                            if(!initialize_called){
                            initialize_called=true;
                            initialize();
                            if(!energy_dec_called){
                            energy_dec_called=true;
                            energy_dec();
                            • 11. Re: Can't remove Event Listener?
                              A am far from an expert and i really appreciate your help, thats why i hate to contradict you, but:
                              • The fact that initialize() is called each time i enter the frame is not a problem, because every time it gets called (exept for the very first time) no code is executed but "trace("Initializer DONT fire");"
                              • the fact that energy_dec() is called each time i enter the frame, is not a problem either. I tried moving energy_dec() into initialize() (so it only gets executed once), it didn't help with the Event Listeners or the Timer...
                              The thing you are suggesting with
                              initialize();
                              doesn't this have the very some effect as the thing i am doing with
                                else
                              initializer=false;
                              Thanks anyway...
                              • 12. Re: Can't remove Event Listener?
                                test the code i suggested.
                                • 13. Re: Can't remove Event Listener?
                                  allright
                                  • 14. Re: Can't remove Event Listener?
                                    doesn't work...now Initialize() and energy_dec() NEVER get executed, not even once...
                                    • 15. Re: Can't remove Event Listener?
                                      you did something wrong.  copy and paste the code you tested.
                                      • 16. Re: Can't remove Event Listener?
                                        var initializer;
                                        var added:Boolean;
                                        var tTrue:Boolean;
                                        // Suggested Code by kglad
                                        Initialize();
                                        energy_dec();
                                        function tTrueSet(e=null)
                                          //energy_dec()
                                          if (tTrue == true)
                                          tTrue=false;
                                          else
                                          tTrue = true;
                                          //t.stop();
                                          //t.removeEventListener(TimerEvent.TIMER,nextFF);
                                          //t=null;
                                          trace ("tTrue = " + tTrue)
                                        function Initialize()
                                          else
                                          var i= null;
                                          StopAll()
                                          resetAlpha()
                                          PercentR = 20;
                                          TextR.stop();
                                          TextL.addEventListener(Event.ENTER_FRAME, Equal_L_to_R);
                                          Slider02.stop()
                                          var MultiplicationFactor = Slider02.totalFrames/100
                                          var Sl02_Target_Frame:uint = Sl02_Target_Percent * MultiplicationFactor
                                          Slider02.gotoAndStop(Sl02_Target_Frame);
                                          //Slider02.Sl02_Target_Frame = Sl02_Target_Frame;
                                          //var Sl02_Current_Frame:uint;
                                          trace ("Sl02_Target_Frame = " +Sl02_Target_Frame)
                                          //Sl02_Current_Frame = Sl02_Target_Frame;
                                          //Slider02.t=new Timer(1000/fps,0);
                                          //Slider02.t.addEventListener(TimerEvent.TIMER,nextFF);
                                          //Slider02.t.start();
                                          t.start();
                                          energy_dec();
                                          initializer=false;
                                        var i:int;
                                        var PercentR:int;
                                        var EL_active_FadeRUPto50 = false;
                                        var EL_active_FadeRto80 = false;
                                        var EL_active_FadeRDownto50 = false;
                                        //var Sl02_Target_Percent = null;
                                        var EL_active_FadeRto20 = false;
                                        //var EL_active_FadeRDownto50 = false;
                                        trace("Alpha Blue=" + WindBlue50.alpha)
                                        trace("Alpha Red=" + WindRed50.alpha)
                                        trace("Alpha White=" + WindWhite50.alpha)
                                        function CheckPerc(e=null):void
                                          if (TextR.PercR >=80)
                                          TextR.addEventListener(Event.ENTER_FRAME, CheckPerc);
                                          TextR.stop();
                                        function timer_dec()
                                          trace ("energy_dec toggled")
                                          if (Sl02_Target_Percent > 30 && EL_dec_present == false)
                                          //EL_dec_present = true;
                                          //if (tTrue = true)
                                          if (added == false)
                                          addEventListener(Event.ENTER_FRAME, energy_dec);
                                          added= true;
                                          trace ("added = " + added)
                                          else
                                          //ifTimerThenFire()
                                          //Sl02_Target_Percent = 30;
                                          trace ("energy_dec fired")
                                          else
                                          if (added ==true)
                                          removeEventListener(Event.ENTER_FRAME, energy_dec);
                                          trace ("REMOVED")
                                          added= false;
                                          if (Sl02_Target_Percent <= 30)
                                          trace ("EL_dec_present = " + EL_dec_present)
                                        //CheckPerc();
                                        function Equal_L_to_R(e=null):void
                                          var PercL = 100 - TextR.PercR
                                          //trace ("PercL= " + PercL)
                                          TextL.text = PercL + "%";
                                          //TextL.text = "23";
                                          //trace (TextL.text)
                                        Equal_L_to_R();
                                        // Slider02 Playback Speed
                                        var currentMC:MovieClip
                                        var fps:int = 1;
                                        function nextFF(e:TimerEvent):void
                                          Slider02.nextFrame();
                                          if(Slider02.currentFrame==Slider02.totalFrames)
                                          Slider02.gotoAndStop(1);
                                          //currentMC.t.removeEventListener(TimerEvent.TIMER,nextFF);
                                          //playF(Slider02,1)
                                          //currentMC.t.stop();
                                          Slider02.t=null;
                                          //Slider02.play()
                                          /* stop after one play
                                          if(currentMC.currentFrame==currentMC.totalFrames)
                                          currentMC.t.stop();
                                          currentMC.t=null;
                                        //Slider03 Code
                                        var SliderValue:uint = mySlider.SliderKnob.x;
                                        addEventListener(Event.ENTER_FRAME, onEnterFrame);
                                        function onEnterFrame(event:Event):void
                                          var ValueMult:Number = 100 / mySlider.boundWidth;
                                          var SliderValue100:uint = SliderValue * ValueMult;
                                          SliderValue = mySlider.SliderKnob.x;
                                          statusTXT.text = "Slider position is: " + SliderValue100 +"SV= "+mySlider.boundWidth;
                                        //____________________________________________
                                        function EL_ADD_FadeRto80_func():void
                                          if (EL_active_FadeRto80 == false)
                                          TextR.addEventListener(Event.ENTER_FRAME, FadeRto80);
                                          EL_active_FadeRto80 = true;
                                          trace ("ADDED_EL FadeRto80 is active = " + EL_active_FadeRto80)
                                        function EL_REMOVE_FadeRto80_func():void
                                          if (EL_active_FadeRto80 == true)
                                          TextR.removeEventListener(Event.ENTER_FRAME, FadeRto80);
                                          trace ("REMOVED_EL FadeRto80 is active = " + EL_active_FadeRto80)
                                        function EL_ADD_FadeRUPto50_func():void
                                          if (EL_active_FadeRUPto50 == false)
                                          TextR.addEventListener(Event.ENTER_FRAME, FadeRUPto50);
                                          EL_active_FadeRUPto50 = true;
                                          trace ("ADDED_EL FadeRUPto50 is active = " + EL_active_FadeRUPto50)
                                        function EL_REMOVE_FadeRUPto50_func():void
                                          if (EL_active_FadeRUPto50 == true)
                                          TextR.removeEventListener(Event.ENTER_FRAME, FadeRUPto50);
                                          trace ("REMOVED_EL FadeRUPto50 is active = " + EL_active_FadeRUPto50)
                                        function EL_ADD_FadeRDownto50_func():void
                                          if (EL_active_FadeRDownto50 == false)
                                          TextR.addEventListener(Event.ENTER_FRAME, FadeRDownto50);
                                          EL_active_FadeRDownto50 = true;
                                          trace ("ADDED_EL FadeRDownto50 is active = " + EL_active_FadeRDownto50)
                                        function EL_REMOVE_FadeRDownto50_func():void
                                          if (EL_active_FadeRDownto50 == true)
                                          TextR.removeEventListener(Event.ENTER_FRAME, FadeRDownto50);
                                          trace ("REMOVED_EL FadeRto80 is active = " + EL_active_FadeRDownto50)
                                        function EL_ADD_FadeRto20_func():void
                                          if (EL_active_FadeRto20 == false)
                                          TextR.addEventListener(Event.ENTER_FRAME, FadeRto20);
                                          EL_active_FadeRto20 = true;
                                          trace ("ADDED_EL FadeRto20 is active = " + EL_active_FadeRto20)
                                        function EL_REMOVE_FadeRto20_func():void
                                          if (EL_active_FadeRto20 == true)
                                          TextR.removeEventListener(Event.ENTER_FRAME, FadeRto20);
                                          trace ("REMOVED_EL FadeRto20 is active = " + EL_active_FadeRto20)
                                        //________________________________________________________________________________________ ___
                                        function FadeRto80(e=null):void{
                                          EL_REMOVE_FadeRto80_func();
                                          TextR.stop();
                                          else{
                                          EL_ADD_FadeRto80_func();
                                          TextR.play();
                                        function FadeRUPto50(e=null):void{
                                          if (TextR.PercR >=50)
                                          EL_REMOVE_FadeRUPto50_func();
                                          TextR.stop();
                                          else{
                                          EL_ADD_FadeRUPto50_func();
                                          TextR.play();
                                        function FadeRDownto50(e=null):void{
                                          if (TextR.PercR <=50)
                                          EL_REMOVE_FadeRDownto50_func();
                                          TextR.stop();
                                          else{
                                          EL_ADD_FadeRDownto50_func();
                                          TextR.play();
                                        function FadeRto20(e=null):void{
                                          if (TextR.PercR <=20)
                                          EL_REMOVE_FadeRto20_func();
                                          TextR.stop();
                                          else{
                                          EL_ADD_FadeRto20_func();
                                          TextR.play();
                                        function PlusRClick(pEvent:MouseEvent):void
                                          TextR.AddTo = true;
                                          if (TextR.PercR < 50)
                                          FadeRUPto50();
                                          else{
                                          if (TextR.PercR < 80)
                                          FadeRto80();
                                        function MinusRClick(pEvent:MouseEvent):void
                                          TextR.AddTo = false;
                                          //EL_active_FadeRUPto50 = false;
                                          if (TextR.PercR > 50)
                                          FadeRDownto50();
                                          else
                                          if (TextR.PercR > 20)
                                          FadeRto20();
                                          //TextR.text = PercentR + "%"
                                        BtnPlusR.addEventListener(MouseEvent.MOUSE_UP, PlusRClick);
                                        BtnMinusR.addEventListener(MouseEvent.MOUSE_UP, MinusRClick);
                                        BtnPlusL.addEventListener(MouseEvent.MOUSE_UP, MinusRClick);
                                        BtnMinusL.addEventListener(MouseEvent.MOUSE_UP, PlusRClick);
                                        function CapAlpha()
                                          if(WindBlue50.alpha >= 1)
                                          WindBlue50.alpha = 1;
                                          if(WindBlue50.alpha <= 0)
                                          WindBlue50.alpha = 0;
                                          if(WindRed50.alpha >= 1)
                                          WindRed50.alpha = 1;
                                          if(WindRed50.alpha <= 0)
                                          WindRed50.alpha = 0;
                                          if(WindWhite50.alpha >= 1)
                                          WindWhite50.alpha = 1;
                                          if(WindWhite50.alpha <= 0)
                                          WindWhite50.alpha = 0;
                                        function FadeBlueIn(event:Event)
                                          if(WindBlue50.alpha <= 1)
                                          WindBlue50.addEventListener(Event.ENTER_FRAME, FadeBlueIn);
                                          //zeroAlpha()
                                          WindBlue50.alpha += 0.1;
                                          WindRed50.alpha -= 0.1;
                                          WindWhite50.alpha -= 0.1;
                                          WindBlue50.play();
                                          CapAlpha();
                                          i++
                                          trace("i=" + i)
                                          if(i >= 10)
                                          i = 0;
                                          trace("Event Listeners removed BLUE");
                                          WindBlue50.removeEventListener(Event.ENTER_FRAME, FadeBlueIn);
                                          WindRed50.stop();
                                          WindWhite50.stop();
                                        function FadeRedIn(event:Event)
                                          if(WindRed50.alpha <= 1)
                                          WindRed50.addEventListener(Event.ENTER_FRAME, FadeRedIn);
                                          //zeroAlpha()
                                          WindBlue50.alpha -= 0.1;
                                          WindRed50.alpha += 0.1;
                                          WindRed50.play();
                                          CapAlpha();
                                          i++
                                          trace("i=" + i)
                                          if(i >= 10)
                                          i = 0;
                                          trace("Event Listeners removed RED");
                                          WindRed50.removeEventListener(Event.ENTER_FRAME, FadeRedIn);
                                          WindBlue50.stop();
                                          WindWhite50.stop();
                                        function FadeWhiteIn(event:Event)
                                          if(WindWhite50.alpha <= 1)
                                          WindWhite50.addEventListener(Event.ENTER_FRAME, FadeWhiteIn);
                                          //zeroAlpha()
                                          WindWhite50.alpha += 0.1;
                                          WindWhite50.play();
                                          CapAlpha();
                                          i++
                                          trace("i=" + i)
                                          if(i >= 10)
                                          i = 0;
                                          trace("Event Listeners removed WHITE");
                                          WindWhite50.removeEventListener(Event.ENTER_FRAME, FadeWhiteIn);
                                          WindBlue50.stop();
                                          WindRed50.stop();
                                        function resetAlpha():void
                                          trace("Alpha reset");
                                        function zeroAlpha():void
                                          trace("Alpha zeroed");
                                        function PlayAll(event:Event)
                                          WindBlue50.play();
                                          WindRed50.play();
                                          WindWhite50.play();
                                        function StopAll(event:Event = null):void
                                          WindBlue50.stop();
                                          WindRed50.stop();
                                          WindWhite50.stop();
                                        // Die drei Buttons callen die jewiligen Functions
                                        BtnKalt.addEventListener(MouseEvent.CLICK, FadeBlueIn);
                                        BtnWarm.addEventListener(MouseEvent.CLICK, FadeRedIn);
                                        BtnNormal.addEventListener(MouseEvent.CLICK, FadeWhiteIn);
                                        BtnPlay.addEventListener(MouseEvent.CLICK, PlayAll);
                                        BtnStop.addEventListener(MouseEvent.CLICK, StopAll);
                                        • 17. Re: Can't remove Event Listener?
                                          that's more code than i'm willing to debug via a forum.  sorry.
                                          i suggest you continue to judiciously use the trace function to debug your code, or wait for someone else to critique your code.
                                          • 18. Re: Can't remove Event Listener?
                                            i thought so...:) I sent you my fla via PM as well... The whole code does work, the problem is only with the Timer Event listeners not getting removed... I think i will try the approach of creating a variable that holds the number of times the timer has to be executed for energy to reach 30. I just thought that this was a common problem and that there was a simple workaround.
                                            Anyways, thanks ALOT for trying to help
                                            kind regards
                                            • 19. Re: Can't remove Event Listener?
                                              i don't download and correct files unless i'm hired.  the only free help i offer is via the forums and because of my mental limitations i'm willing to debug a limited number of lines of code in the forums.  if i were smarter maybe i could easily debug your message 16 code, but i cannot easily debug that unless i copy it and use the debugging tools in animate.
                                              • 20. Re: Can't remove Event Listener?
                                                I completely understand. I would be willing to pay you 50 bucks for an hour of your time, no matter the outcome. we could have a skype/teamviewer debug session tomorrow. Tell me if you are interested...
                                                • 21. Re: Can't remove Event Listener?
                                                  i don't think it will cost that much.  i'll download your file and let you know.
                                                  p.s.  you can contact me via http://www.kglad.com > contact
