Export PDF has stopped working - previously i clicked on a pdf file and was offered a box saying "convert file" which has suddenly stopped appearing after 6 months - how do i get it back?Export PDF has stopped working - previously i clicked on a pdf file and was offered a box saying "convert file" which has suddenly stopped appearing after 6 months - how do i get it back?
Hi kevinb441118,
As per the description mentioned above, you are unable to Export PDF, is that correct?
Assuming you are using Acrobat Reader to Export PDF file, could you please try updating Reader and see if that helps?
Launch Reader>click Help>select Check for Updates
You may refer to this link discussing the same topic: Export PDF not working from within Adobe Reader
Are you exporting PDF in Acrobat Reader or online @ https://cloud.acrobat.com/exportpdf ?
Awaiting your response.
Shivam
