6 Replies Latest reply on May 25, 2017 2:19 AM by Heleyon
    Date field in file-save
    Heleyon
      When saving JPEGs from Camera Raw, I always insert a second field with the current date, in the ddmmyy format.
      This worked fine until a few months ago, when the file names started showing "ddmmyy (date)" instead of inserting the date itself.
      Unusually, I can't find this error on web searches.
      Thanks in advance.
        • 1. Re: Date field in file-save
          Jeff Arola Adobe Community Professional
          What operating system, version of photoshop and camera raw are you using?
          You might try resetting the camera raw preferences.
          Open photoshop.
          Hold down the Shift+Ctrl+Alt (windows) or Shift-Command-Option (mac) keys and then go to File>Open and click on one of your camera raw files.
          Keep holding keys down until you get a reset dialog as below
          Press Yes
          • 2. Re: Date field in file-save
            Heleyon Level 1
            Thanks. Here's the info:
            WIndows 10 Home
            Photoshop 5.1 (64)
            Bridge 5
            Camera Raw 6.7
            • 3. Re: Date field in file-save
              Did you reset the camera raw preferences as explained in my last reply?
              • 4. Re: Date field in file-save
                Heleyon Level 1
                That key combination does nothing, I'm afraid.
                • 5. Re: Date field in file-save
                  In photoshop hold down Shift+Ctrl+Alt while clicking on File>Open Recent, clicking on one of your raw files and keeping holding the keys until you get the reset dialog.
                  • 6. Re: Date field in file-save
                    Heleyon Level 1
                    SOLVED
                    Thanks, but the key combination above allowed the resetting of preferences only when I open the file using the Open Recent option, not when opening in the usual way. In any case, it doesn't solve the date problem.
                    The issue is to do with how I've been constructing the file's name. I use a name, date and serial number. These are separated by spaces and hyphens. Here's a way to do it which doesn't work:
                    It was only through changing the way I entered the fields I discovered that if you insert any text in an automatic field like date or serial number, it converts the whole field to text. So now I build the fields this way:
                    So although I can insert spaces and a hyphen in the first file-name field - because it's text - the same elements between the date and serial number fields have to be in their own [text] field.
                    I wrote all this only because there may be someone else who likes to format the file's name in this way.
