3 Replies Latest reply on May 21, 2017 2:49 PM by Nexahs1138
    Multiple Resolutions in One Composition
      So I'm trying to render and export a composition that contains multiple clips with different resolutions (some are 360, some are 1080, etc). Unfortunately even when I render them separately, and then put them into one composition that I can use to edit them, it either crops the larger resolution or puts the smaller resolution in this big black rectangle. Is there any way I can render and then export compositions that contain clips with multiple resolutions?
        • 1. Re: Multiple Resolutions in One Composition
          How should that even be possible unless you scale the clips in some way? I'm afraid your approach makes no sense. AE simply doesn't adapt anything automatically. In your case obviously you would have to scale up the small clips to fit in a HD comp.
          • 2. Re: Multiple Resolutions in One Composition
            wills667 Level 1
            Ok and just to be sure (I'm new to this so thank you for bearing with me) scaling up, say, a 480 or 720 image to 1080 will result in a loss of resolution, right? Because that's kind of what it looks like now but I can't tell if I'm just doing it wrong ¯\_(ツ)_/¯
            • 3. Re: Multiple Resolutions in One Composition
              Nexahs1138 Level 3
              Reading your question has me like
              Whatever you scale up will depend on the quality it was shot at. It's about the resolution, so something that is 1080p can be viewed at any size and be lossless
              Think of YouTube, you have normal, cinema, and full screen. The 1080p can be played in all the modes and look the same but a 360p will look crap on everything (worse on cinema and full screen.)
