0 Replies Latest reply on May 21, 2017 4:34 AM by poomanis87394962
    Echosign RestAPI Access Token Generation in C#
    poomanis87394962 Level 1
      Hi All,
      I have download the Echosign Rest Client API and consume the same in my Asp.Net web application. Can you tell me, How to create Access Token? I have passed the required parameter to below method but Access token is null.
      /// <summary>
              /// Initialize EchosignREST without Access Token. Must call Authorize() after initialization to acquire Access Token.
              /// </summary>
              /// <param name="apiUrl">API url returned from the authorization request URL</param>
              /// <param name="clientId">Application/Client ID</param>
              /// <param name="secretId">Client Secret</param>
      public EchosignREST(string apiUrl, string clientId, string secretId)
                  this.apiUrl = apiUrl;
                  this.clientId = clientId;
                  this.secretId = secretId;
                  client = new HttpClient();
                  client.BaseAddress = new Uri(apiUrl);
      How to access below method without creating Access Token by above method?
      /// <summary>
              /// Obtain Access Token for the Echosign REST API (use only if you don't already have a Refresh Token, or if it is expired)
              /// </summary>
              /// <param name="authCode">Authorization code received from the authorization request</param>
              /// <param name="redirect_uri">Redirect URI matching the one specified in the authorization request</param>
              /// <returns></returns>
              public async Task Authorize(string authCode, string redirect_uri)
                  using (HttpContent content = new FormUrlEncodedContent(new List<KeyValuePair<string, string>>
                      new KeyValuePair<string, string>("grant_type", "authorization_code"),
                      new KeyValuePair<string, string>("client_id", clientId),
                      new KeyValuePair<string, string>("client_secret", secretId),
                      new KeyValuePair<string, string>("code", authCode),
                      new KeyValuePair<string, string>("redirect_uri", redirect_uri)
                      HttpResponseMessage result = await client.PostAsync("oauth/token", content).ConfigureAwait(false);
                      if (result.IsSuccessStatusCode)
                          string response = await result.Content.ReadAsStringAsync();
                          TokenResponse tokenObj = JsonConvert.DeserializeObject<TokenResponse>(response);
                          this.accessToken = tokenObj.access_token;
                          this.accessTokenExpires = tokenObj.expires_in;
                          this.refreshToken = tokenObj.refresh_token;
                          client.DefaultRequestHeaders.Remove("Access-Token");
                          client.DefaultRequestHeaders.Add("Access-Token", accessToken);
                      else
                          string response = await result.Content.ReadAsStringAsync().ConfigureAwait(false);
                          HandleError(result.StatusCode, response, true);
      Thanks & Regards
      Poomani Sankaran
