13 Replies Latest reply on May 22, 2017 7:28 PM by camelbreath
    No folder options when running batch
    camelbreath Level 1
      When I attempt to run automate>batch, select my action, and then select the folder on which to run the action, the interface gives me two choices, desktop and my username for this computer. Formerly, I would get a display of hard drives, this computer, etc. I deleted preferences and restarted and that made no difference. I changed actions and that made no difference - and when I attempted to do a screen shot, Windows one drive pops up. I have created and used a lot of actions in my workflow and now Photoshop is keeping me out of my folders where I want to run the actions. Can anyone help?
      Joe
        • 1. Re: No folder options when running batch
          Supply pertinent information for quicker answers
          • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
          • Adobe product and version number
          • Operating system and version number
          • The full text of any error message(s)
          • What you were doing when the problem occurred
          • Screenshots of the problem
          • Computer hardware, such as CPU; GPU; amount of RAM; etc.
          Desktop should have all on windows.
          • 2. Re: No folder options when running batch
            camelbreath Level 1
            I will grab the info and submit.
            Joe
            • 3. Re: No folder options when running batch
              camelbreath Level 1
              Also, the sequence you are showing on the screen shot, is the exact procedure I am following.
              TNX,
              Joe
              • 4. Re: No folder options when running batch
                camelbreath Level 1
                Photoshop info
                Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099  x64
                Number of Launches: 3
                Version: 10 or greater
                System architecture: Intel CPU Family:6, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                Physical processor count: 6
                Logical processor count: 12
                Processor speed: 3498 MHz
                Built-in memory: 32670 MB
                Free memory: 2 MB
                Memory available to Photoshop: 29458 MB
                Memory used by Photoshop: 70 %
                History Thumbnails: Enabled.
                Touch Bar: Enabled.
                Alias Layers: Disabled.
                Modifier Palette: Enabled.
                3D Multitone Printing: Disabled.
                Highbeam: Enabled.
                Image tile size: 1024K
                Image cache levels: 4
                Font Preview: Medium
                TextComposer: Latin
                Display: 1
                Display Bounds: top=0, left=0, bottom=1200, right=1920
                Display: 2
                Display Bounds: top=-70, left=1920, bottom=1130, right=3840
                OpenGL Drawing: Enabled.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Drawing Mode: Advanced
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=1
                NumNativeGPUs=0
                glgpu[0].GLVersion="4.1"
                glgpu[0].IsIntegratedGLGPU=0
                glgpu[0].GLMemoryMB=4096
                glgpu[0].GLName="NVIDIA GeForce GTX 980"
                glgpu[0].GLVendor="NVIDIA Corporation"
                glgpu[0].GLVendorID=4318
                glgpu[0].GLDriverVersion="22.21.13.8165"
                glgpu[0].GLRectTextureSize=16384
                glgpu[0].GLRenderer="GeForce GTX 980/PCIe/SSE2"
                glgpu[0].GLRendererID=5056
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um ,nvwgf2um,nvwgf2um"
                glgpu[0].GLDriverDate="20170331000000.000000-000"
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                clgpu[0].CLPlatformVersion="1.2"
                clgpu[0].CLDeviceVersion="1.2 CUDA"
                clgpu[0].IsIntegratedCLGPU=0
                clgpu[0].CLMemoryMB=4096
                clgpu[0].CLName="GeForce GTX 980"
                clgpu[0].CLVendor="NVIDIA Corporation"
                clgpu[0].CLVendorID=4318
                clgpu[0].CLDriverVersion="381.65"
                clgpu[0].CLBandwidth=1.54957e+11
                clgpu[0].CLCompute=2102.2
                License Type: Subscription
                Serial number: 90970341397659194013
                GUIDBucket:
                  bucket: 16
                  test: control
                Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                Temporary file path: C:\Users\test\AppData\Local\Temp\
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 930.7G, 385.9G free
                Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
                Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                Installed components:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2016/11/04-01:10:53   79.578171   79.578171
                   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                   AdobeOwl.dll   Adobe Owl   5.2.11
                   AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                   AdobeSVGAGM.dll   AdobeSVGAGM   79.578171   79.578171
                   AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                   AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                   AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                   adobe_caps.dll   Adobe CAPS   10,0,0,6
                   AGM.dll   AGM 2016/11/04-01:10:53   79.578171   79.578171
                   ahclient.dll    AdobeHelp Dynamic Link Library   2.0.0.2
                   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                   amtlib.dll   AMTLib (64 Bit)   10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17)   1.000000
                   ARE.dll   ARE 2016/11/04-01:10:53   79.578171   79.578171
                   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                   Bib.dll   BIB 2016/11/04-01:10:53   79.578171   79.578171
                   BIBUtils.dll   BIBUtils 2016/11/04-01:10:53   79.578171   79.578171
                   boost_date_time.dll   photoshopdva   10.0.0
                   boost_signals.dll   photoshopdva   10.0.0
                   boost_system.dll   photoshopdva   10.0.0
                   boost_threads.dll   photoshopdva   10.0.0
                   cg.dll   NVIDIA Cg Runtime   3.0.00007
                   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                   CIT.dll   Adobe CIT   2.1.0.1   2.1.0.1
                   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                   CoolType.dll   CoolType 2016/11/04-01:10:53   79.578171   79.578171
                   dnssd.dll   Bonjour   3,0,0,2
                   dvaaudiodevice.dll   photoshopdva   10.0.0
                   dvacore.dll   photoshopdva   10.0.0
                   dvamarshal.dll   photoshopdva   10.0.0
                   dvamediatypes.dll   photoshopdva   10.0.0
                   dvametadata.dll   photoshopdva   10.0.0
                   dvametadataapi.dll   photoshopdva   10.0.0
                   dvametadataui.dll   photoshopdva   10.0.0
                   dvaplayer.dll   photoshopdva   10.0.0
                   dvatransport.dll   photoshopdva   10.0.0
                   dvaui.dll   photoshopdva   10.0.0
                   dvaunittesting.dll   photoshopdva   10.0.0
                   dynamiclink.dll   photoshopdva   10.0.0
                   ExtendScript.dll   ExtendScript 2016/01/26-16:09:33   80.1060872   80.1060872
                   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   igestep30.dll   IGES Reader   9.3.0.113
                   imslib.dll   IMSLib DLL   10.0.0.1
                   JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                   LogSession.dll   LogSession   7.4.1.60.45263
                   mediacoreif.dll   photoshopdva   10.0.0
                   MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CC 2017   18.0.1
                   Plugin.dll   Adobe Photoshop CC 2017   18.0.1
                   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                   PSArt.dll   Adobe Photoshop CC 2017   18.0.1
                   PSViews.dll   Adobe Photoshop CC 2017   18.0.1
                   SCCore.dll   ScCore 2016/01/26-16:09:33   80.1060872   80.1060872
                   SVGRE.dll   SVGRE   79.578171   79.578171
                   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                   wu3d.dll   U3D Writer   9.3.0.113
                Required plug-ins:
                   3D Studio 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Accented Edges 18.0.1 - from the file “Filter Gallery.8bf”
                   Adaptive Wide Angle 18.0.1 - from the file “Adaptive Wide Angle.8bf”
                   Angled Strokes 18.0.1 - from the file “Filter Gallery.8bf”
                   Average 18.0.1 (2017.0.1 x001 x003) - from the file “Average.8bf”
                   Bas Relief 18.0.1 - from the file “Filter Gallery.8bf”
                   BMP 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Camera Raw 9.9 - from the file “Camera Raw.8bi”
                   Camera Raw Filter 9.9 - from the file “Camera Raw.8bi”
                   Chalk && Charcoal 18.0.1 - from the file “Filter Gallery.8bf”
                   Chrome 18.0.1 - from the file “Filter Gallery.8bf”
                   Cineon 18.0.1 (2017.0.1 x001 x003) - from the file “Cineon.8bi”
                   Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
                   Collada 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Color Halftone 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Colored Pencil 18.0.1 - from the file “Filter Gallery.8bf”
                   CompuServe GIF 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Conté Crayon 18.0.1 - from the file “Filter Gallery.8bf”
                   Craquelure 18.0.1 - from the file “Filter Gallery.8bf”
                   Crop and Straighten Photos 18.0.1 (2017.0.1 x001 x003) - from the file “CropPhotosAuto.8li”
                   Crop and Straighten Photos Filter 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Crosshatch 18.0.1 - from the file “Filter Gallery.8bf”
                   Crystallize 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Cutout 18.0.1 - from the file “Filter Gallery.8bf”
                   Dark Strokes 18.0.1 - from the file “Filter Gallery.8bf”
                   De-Interlace 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Dicom 18.0.1 - from the file “Dicom.8bi”
                   Difference Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
                   Diffuse Glow 18.0.1 - from the file “Filter Gallery.8bf”
                   Displace 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Dry Brush 18.0.1 - from the file “Filter Gallery.8bf”
                   Eazel Acquire 18.0.1 (2017.0.1 x001 x003) - from the file “EazelAcquire.8ba”
                   Entropy 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Export Color Lookup Tables NO VERSION - from the file “Export3DLUT.8be”
                   Extrude 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   FastCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “FastCore.8bx”
                   Fibers 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Film Grain 18.0.1 - from the file “Filter Gallery.8bf”
                   Filter Gallery 18.0.1 - from the file “Filter Gallery.8bf”
                   Flash 3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Fresco 18.0.1 - from the file “Filter Gallery.8bf”
                   Glass 18.0.1 - from the file “Filter Gallery.8bf”
                   Glowing Edges 18.0.1 - from the file “Filter Gallery.8bf”
                   Google Earth 4 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Graphic Pen 18.0.1 - from the file “Filter Gallery.8bf”
                   Halftone Pattern 18.0.1 - from the file “Filter Gallery.8bf”
                   HDRMergeUI 18.0.1 - from the file “HDRMergeUI.8bf”
                   HSB/HSL 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   IFF Format 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   IGES 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Ink Outlines 18.0.1 - from the file “Filter Gallery.8bf”
                   JPEG 2000 18.0.1 - from the file “JPEG2000.8bi”
                   Kurtosis 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Lens Blur 18.0.1 - from the file “Lens Blur.8bf”
                   Lens Correction 18.0.1 - from the file “Lens Correction.8bf”
                   Lens Flare 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Liquify 18.0.1 - from the file “Liquify.8bf”
                   Matlab Operation 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
                   Maximum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Mean 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Measurement Core 18.0.1 (2017.0.1 x001 x003) - from the file “MeasurementCore.8me”
                   Median 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Mezzotint 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Minimum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   MMXCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “MMXCore.8bx”
                   Mosaic Tiles 18.0.1 - from the file “Filter Gallery.8bf”
                   Multiprocessor Support 18.0.1 (2017.0.1 x001 x003) - from the file “MultiProcessor Support.8bx”
                   Neon Glow 18.0.1 - from the file “Filter Gallery.8bf”
                   Note Paper 18.0.1 - from the file “Filter Gallery.8bf”
                   NTSC Colors 18.0.1 (2017.0.1 x001 x003) - from the file “NTSC Colors.8bf”
                   Ocean Ripple 18.0.1 - from the file “Filter Gallery.8bf”
                   OpenEXR 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Paint Daubs 18.0.1 - from the file “Filter Gallery.8bf”
                   Palette Knife 18.0.1 - from the file “Filter Gallery.8bf”
                   Patchwork 18.0.1 - from the file “Filter Gallery.8bf”
                   Paths to Illustrator 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   PCX 18.0.1 (2017.0.1 x001 x003) - from the file “PCX.8bi”
                   Photocopy 18.0.1 - from the file “Filter Gallery.8bf”
                   Photoshop 3D Engine 18.0.1 (2017.0.1 x001 x003) - from the file “Photoshop3DEngine.8bi”
                   Photoshop Touch 14.0 - from the file “PSDX.8bi”
                   Picture Package Filter 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
                   Pinch 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Pixar 18.0.1 (2017.0.1 x001 x003) - from the file “Pixar.8bi”
                   Plaster 18.0.1 - from the file “Filter Gallery.8bf”
                   Plastic Wrap 18.0.1 - from the file “Filter Gallery.8bf”
                   PLY 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   PNG 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Pointillize 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Polar Coordinates 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Portable Bit Map 18.0.1 (2017.0.1 x001 x003) - from the file “PBM.8bi”
                   Poster Edges 18.0.1 - from the file “Filter Gallery.8bf”
                   PRC 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Radial Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Radiance 18.0.1 (2017.0.1 x001 x003) - from the file “Radiance.8bi”
                   Range 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Render Color Lookup Grid NO VERSION - from the file “Export3DLUT.8be”
                   Reticulation 18.0.1 - from the file “Filter Gallery.8bf”
                   Ripple 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Rough Pastels 18.0.1 - from the file “Filter Gallery.8bf”
                   Save for Web 18.0.1 - from the file “Save for Web.8be”
                   ScriptingSupport 18.0.1 - from the file “ScriptingSupport.8li”
                   Shake Reduction 18.0.1 - from the file “Shake Reduction.8bf”
                   Shear 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Skewness 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Smart Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Smudge Stick 18.0.1 - from the file “Filter Gallery.8bf”
                   Solarize 18.0.1 (2017.0.1 x001 x003) - from the file “Solarize.8bf”
                   Spaces 18.0.1 - from the file “Spaces.8li”
                   Spatter 18.0.1 - from the file “Filter Gallery.8bf”
                   Spherize 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Sponge 18.0.1 - from the file “Filter Gallery.8bf”
                   Sprayed Strokes 18.0.1 - from the file “Filter Gallery.8bf”
                   Stained Glass 18.0.1 - from the file “Filter Gallery.8bf”
                   Stamp 18.0.1 - from the file “Filter Gallery.8bf”
                   Standard Deviation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   STL 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Sumi-e 18.0.1 - from the file “Filter Gallery.8bf”
                   Summation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Targa 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Texturizer 18.0.1 - from the file “Filter Gallery.8bf”
                   Tiles 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Torn Edges 18.0.1 - from the file “Filter Gallery.8bf”
                   Twirl 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   U3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Underpainting 18.0.1 - from the file “Filter Gallery.8bf”
                   Vanishing Point 18.0.1 - from the file “VanishingPoint.8bf”
                   Variance 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
                   Virtual Reality Modeling Language | VRML 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   Water Paper 18.0.1 - from the file “Filter Gallery.8bf”
                   Watercolor 18.0.1 - from the file “Filter Gallery.8bf”
                   Wave 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Wavefront|OBJ 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
                   WIA Support 18.0.1 (2017.0.1 x001 x003) - from the file “WIASupport.8li”
                   Wind 18.0.1 - from the file “Standard MultiPlugin.8bf”
                   Wireless Bitmap 18.0.1 (2017.0.1 x001 x003) - from the file “WBMP.8bi”
                   ZigZag 18.0.1 - from the file “Standard MultiPlugin.8bf”
                Optional and third party plug-ins:
                   Extensis 18.2.3.96 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Automate\ExtensisFontManagementPSCC2017x64.8li”
                   Fixel Detailizer 2 PS 15.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Fixel Algorithms\Fixel Detailizer 2 PS.8bf”
                   Perfect Batch 9 9.5.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Perfect Batch 9.plugin\PerfectBatchProxy.8li”
                   Perfect Resize 9 9.5.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Perfect Resize 9.plugin\PerfectResizeProxy.8li”
                   Perfect Resize 9 Engine Automation 9.5.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Perfect Resize 9.plugin\PerfectResizeProxy.8li”
                   Perfect Resize 9 Engine Filter 9.5.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Perfect Resize 9.plugin\PerfectResizeProxy.8li”
                   Perfect Resize 9 Standalone Filter 9.5.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Perfect Resize 9.plugin\PerfectResizeProxy.8li”
                   Reduce Noise v8 8.1.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\NeatImage8.8bf”
                Duplicate and Disabled plug-ins: NONE
                Plug-ins that failed to load: NONE
                Extensions:
                   Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                   Retouching tools  1.3.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\Retouchingtools\index.html”
                   com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                   Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                   Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                   onOne  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\onOne\index.html”
                   Blendit  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\Blendit\index.html”
                   Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                   Adobe Paper Texture Pro  3.1.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.AdobePaperTexturePro\index.html”
                   Extensis  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\Extensis_Photoshop_HTML\index.html”
                   com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                   New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                   com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                   Ultimate Retouch 3.0  3.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\UltimateRetouch3\index.html”
                   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                   Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                   ALCE  2.3.1 - from the file “C:\Users\test\AppData\Roaming\Adobe\CEP\extensions\com.cs-extensions.AdvancedLocalContra stEnhancer\index.html”
                Installed TWAIN devices: NONE
                • 5. Re: No folder options when running batch
                  camelbreath Level 1
                  Windows 10
                  Version 1500
                  OS Build 10586.333
                  • 6. Re: No folder options when running batch
                    camelbreath Level 1
                    This is what I get on each attempt to run an action. "test" is the user windows user name.
                    Joe
                    • 7. Re: No folder options when running batch
                      You are missing one of the CC 2017 updates and the windows folder dialog is wrong. Uninstall CC 2017 and re-install
                      • 8. Re: No folder options when running batch
                        camelbreath Level 1
                        JJ, thanks a bunch!!
                        Joe
                        • 9. Re: No folder options when running batch
                          camelbreath Level 1
                          That MVP by your name is the real thing!
                          TNX,
                          Joe
                          • 10. Re: No folder options when running batch
                            camelbreath Level 1
                            One more question. I have a lot of actions saved. How can I preserve those and uninstall the program.
                            Joe
                            • 11. Re: No folder options when running batch
                              camelbreath Level 1
                              JJ, I did the uninstall and reinstalled saving preferences and got the same results. Then uninstalled and reinstalled removing preferences and still got the same results. Also restarted after the both reinstalls. Any ideas on what to do next?
                              Joe
                              • 12. Re: No folder options when running batch
                                The Creative desktop application did not install CC 2017.1.1 and ACR 9.10. If that is what happened. Try uninstalling the Creative Cloud Desktop Application. The download and install the latest version of the Creative cloud Desktop application.  Install it and see if the will update CC 2017 to cc 2017.1.1.
                                • 13. Re: No folder options when running batch
                                  camelbreath Level 1
                                  Will do JJ. Thanks for your patience in sticking with me.
                                  Joe
