3 Replies Latest reply on May 31, 2017 4:01 PM by Eli-zabelle
    Wanting fields with default values to hide
    Eli-zabelle
      I'm an absolute beginner with JS. I'm trying to get multiple fields holding default values to hide when I use a checkbox.  This is my code
      var nHide = event.target.isBoxChecked(0)? display.hidden:display.visible;
      var f = this.getField("TitreNom4L"); if(f.value==f.defaultValue) f.display = nHide;
      However, all the fields hide, even when the default value has been replaced. Please help me with what I am doing wrong.
      Note : At first, i wanted it as an action just before print, but nothing happened at all. At least with a checkbox the fields do react.
      Thank you.
        • 1. Re: Wanting fields with default values to hide
          George_Johnson MVP & Adobe Community Professional
          Where did you place that code - what field and what event (e.g., Mouse Up event of a check box)
          • 2. Re: Wanting fields with default values to hide
            JR_Boulay Adobe Community Professional
            Place default texts as "default value" in your text fields, and place this JavaScript as a Custom Format Script:
            sValDefo = event.target.defaultValue;
            if (!event.value) {
                // manage value
                event.value = sValDefo;
                // manage text color
                event.target.textColor = event.value == sValDefo ? color.ltGray : color.black;
            • 3. Re: Wanting fields with default values to hide
              Eli-zabelle Level 1
              I was able to solve my problem with findings after I browsed discussions here. My working code, which doesn't print a default text and colors it gray, but makes the new entry printable, black and uppercase, is now this one :
              in custom format script :
              // If field is blank, do not print this field
              event.target.display = event.value ? display.visible : display.noPrint;
              // If field is blank, display this text
              if (!event.value) event.value = "Receiver", event.target.textColor = color.gray;
              else
              event.value = event.value.toUpperCase(), event.target.textColor = color.black;
              To make it work properly, I must eliminate all default text from the options tab. However, my new problem is that it can't apply to one of my fields, a dropdown list, because this one can't be without a default text. And I have tried to alter my code to make it work but couldn't come up with a solution.
              Any ideas on how to make a similar code for a dropdown list?
              Thank you.
              I'm replying to myself again...if it should be useful for someone. I found my second solution using an array to represent my dropdown list.
              var multipleValues = [];
              multipleValues[0]="Prov";
              multipleValues[1]="QC";
              multipleValues[2]="ON";
              multipleValues[3]="NS";
              if(event.target.value == multipleValues[0])
              event.target.display = display.noPrint, event.target.textColor = color.gray;
              else
              event.target.display = display.visible, event.target.textColor = color.black;
