1 Reply Latest reply on May 22, 2017 8:26 PM by foughtthelaw
    Fixing Script
    madhfarid
      Hello.. i need help badly..
      now i am working on a project that requires me to set frames vertically like that.. i have to do more than 200 frames manually daily.. setting them frame by frame.. it takes a lot of effort and is really tiring.. i dont know how to script.. i am not a pro or anything.. just a simple user and this is giving me nightmares
      i searched on the internet and i found a script for AE here Rendering png/jpg sequence into one png/jpg file .. i tried to use it but its not accurate..
      as u can see i have the frames at the edges
      http://prntscr.com/fakd8p
      but when i apply the script they look like that.. i cant have that space at the top.. i need it to be starting from the very top pixel
      http://prntscr.com/fakdde
      also frames are into eachother by 1 pixel..
      http://prntscr.com/fakdg2
      will anyone help me to fix this script please ? i am so tired.. i literally spend 12 hrs everyday just to adjust all frames 1 by 1
      thank you so much
        • 1. Re: Fixing Script
          foughtthelaw Adobe Community Professional
          yeah that expression won't help you and you're WAY overthinking this. try this:
          1. set your comp height to the height of each frame * the number of frames (so 100 frames 100px tall would be a 10,000px tall comp)
          2. select ALL layers and set the Position to (0,0) and the Anchor point to (0,0) and all your layers will be a the top of the comp
          3. select the first layer and apply the following expression to the position value
                    x = value[0];
                    y = thisLayer.height*(index-1);
                    [x,y]
          then select the top layers position, copy, and select ALL layers and paste. your layers will be perfectly spaced out vertically based on their order in the comp.
