6 Replies Latest reply on May 25, 2017 6:08 AM by M_Schloegl
    "Select and Mask" causing WHEA_uncorrectable_error
    M_Schloegl Level 1
      Hello, .
      I recently upgraded from CS4 to CC to make use of the new masking features. Now, I've never had a BSOD on this machine in half a decade at least, but "Select and Mask" has crashed it violently 3 times already
      Not only does the tool have trouble updating the visual output on screen (rotating circle til eternity or until I press Escape, or start drawing on another part of the mask, and if clicking "OK" is possible, it'll take a a few moments for artefacts/panel "residue" to disappear.
      I'm running:
      1. Windows 8.1 64bits
      2. 16GB matched RAM
      3. 3 SSDs (sys, apps, scratch)
      4. several HDDs
      5. EVGA 980GTX classified
      6. AMD Phenom 1100T
      7. ASUS Sabertooth 990FX R 2.0
      I have seen that only the mobile versions of my GPU seem to have been tested, does that make a difference? Since the error only, exclusively, occurs when using OpenGL in Photoshop, is it likely to be connected to the GPU and if yes, how can i determine that (aside from disabling GPU usage)?
      I'm frequently using my GPU for 3D rendering in several applications, and it has never crashed my system before.
      I've read about possible CPU undervoltage, bad device drivers etc., it's just strange it only occurs within Photoshop CC.
      Furthermore, there's no file recovery happening. Not even the folder exists, although checked in the settings. Makes it hard to work with, CS4 now looks like an upgrade.
      Please advise, thank you :-)
      [Moved by moderator from the non-technical Lounge Forum to the Photoshop Forum for technical help]
        • 1. Re: "Select and Mask" causing WHEA_uncorrectable_error
          Please post you Photoshop menu Help>System Info.  Also if Photoshop crashes on your Windows without causing a BSOD post the widows crash information details.
          • 2. Re: "Select and Mask" causing WHEA_uncorrectable_error
            M_Schloegl Level 1
            Here we go, thanks for your help!
            [Sorry it's in German, in case you can't make heads or tails out of this, I'll switch the application language (if possible)]
            Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
            Anzahl der Starts: 29
            Version: 8.1
            Systemarchitektur: AMD CPU-Familie:15, Modell:10, Stepping:0 mit MMX, SSE (ganze Zahl), SSE FP, SSE2, SSE3
            Physischer Prozessor: 6
            Prozessor-Taktfrequenz: 3712 MHz
            Eingebauter Speicher: 12203 MB
            Freier Speicher: 6700 MB
            Für Photoshop verfügbarer Arbeitsspeicher: 10695 MB
            Von Photoshop verwendeter Arbeitsspeicher: 71 %
            Verlaufsminiaturen: Aktiviert.
            Touch Bar: Aktiviert.
            Alias-Ebenen: Deaktiviert.
            Zusatztasten-Palette: Aktiviert.
            Fernlicht: Aktiviert.
            Bildkachelgröße: 1028 KB
            Bildcache: 4
            Schriftvorschau: Mittel
            TextComposer: Lateinisch
            Anzeige: 1
            Anzeigebegrenzungen: oben= 0, links= 0, unten= 1200, rechts= 1920
            Anzeige: 2
            Anzeigebegrenzungen: oben= 0, links= 1920, unten= 1200, rechts= 3840
            Mit OpenGL zeichnen: Aktiviert.
            OpenGL – alte GPUs zulassen: Nicht erkannt.
            OpenGL-Zeichnungsmodus: Erweitert
            OpenGL – normalen Modus zulassen: Wahr.
            OpenGL – erweiterten Modus zulassen: Wahr.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=1
            NumNativeGPUs=0
            glgpu[0].GLVersion="4.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=4096
            glgpu[0].GLName="NVIDIA GeForce GTX 980"
            glgpu[0].GLVendor="NVIDIA Corporation"
            glgpu[0].GLVendorID=4318
            glgpu[0].GLDriverVersion="22.21.13.8205"
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="GeForce GTX 980/PCIe/SSE2"
            glgpu[0].GLRendererID=5056
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
            glgpu[0].GLDriverDate="20170501000000.000000-000"
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.2"
            clgpu[0].CLDeviceVersion="1.2 CUDA"
            clgpu[0].IsIntegratedCLGPU=0
            clgpu[0].CLMemoryMB=4096
            clgpu[0].CLName="GeForce GTX 980"
            clgpu[0].CLVendor="NVIDIA Corporation"
            clgpu[0].CLVendorID=4318
            clgpu[0].CLDriverVersion="382.05"
            clgpu[0].CLBandwidth=1.61022e+11
            clgpu[0].CLCompute=2341.28
            Lizenztyp: Abonnement
            Seriennummer: 96040587557108507509
            GUIDBucket:
              bucket: 6
              test: control
            Anwendungsordner: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
            Pfad für temporäre Dateien: E:\TMP\
            Der virtuelle Speicher von Photoshop hat asynchronen E/A aktiviert
            Arbeitsvolume(s):
            I:\, 139,7 GB, 51,3 GB frei
            Z:\, 209,5 GB, 175,8 GB frei
            Ordner für erforderliche Zusatzmodule: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
            Primärer Zusatzmodul-Ordner: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
            Installierte Komponenten
               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
               ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
               AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
               AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
               AdobeOwl.dll   Adobe Owl   5.2.11
               AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
               AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
               AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
               AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
               AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
               AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
               adobe_caps.dll   Adobe CAPS   10,0,0,6
               AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
               ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
               AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
               amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
               ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
               AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
               AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
               Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
               BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
               boost_date_time.dll   photoshopdva   10.0.0
               boost_signals.dll   photoshopdva   10.0.0
               boost_system.dll   photoshopdva   10.0.0
               boost_threads.dll   photoshopdva   10.0.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
               CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
               dnssd.dll   Bonjour   3,0,0,2
               dvaaudiodevice.dll   photoshopdva   10.0.0
               dvacore.dll   photoshopdva   10.0.0
               dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
               dvamarshal.dll   photoshopdva   10.0.0
               dvamediatypes.dll   photoshopdva   10.0.0
               dvametadata.dll   photoshopdva   10.0.0
               dvametadataapi.dll   photoshopdva   10.0.0
               dvametadataui.dll   photoshopdva   10.0.0
               dvaplayer.dll   photoshopdva   10.0.0
               dvatransport.dll   photoshopdva   10.0.0
               dvaui.dll   photoshopdva   10.0.0
               dvaunittesting.dll   photoshopdva   10.0.0
               dynamiclink.dll   photoshopdva   10.0.0
               ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
               icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               igestep30.dll   IGES Reader   9.3.0.113
               imslib.dll   IMSLib DLL   10.0.0.11
               JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               LogSession.dll   LogSession   7.4.1.60.45263
               mediacoreif.dll   photoshopdva   10.0.0
               MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
               Plugin.dll   Adobe Photoshop CC 2017   18.1.1
               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
               PSArt.dll   Adobe Photoshop CC 2017   18.1.1
               PSViews.dll   Adobe Photoshop CC 2017   18.1.1
               SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
               SVGRE.dll   SVGRE   79.579975   79.579975
               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
               TfFontMgr.dll   FontMgr   9.3.0.113
               TfKernel.dll   Kernel   9.3.0.113
               TFKGEOM.dll   Kernel Geom   9.3.0.113
               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
               updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
               VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
               VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
               WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
               wu3d.dll   U3D Writer   9.3.0.113
            Erforderliche Zusatzmodule:
               3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Adaptive Weitwinkelkorrektur 18.1.1 - aus der Datei "“Adaptive Wide Angle.8bf”"
               Aquarell 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Basrelief 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Bereich 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Bildpaket-Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“ChannelPort.8bf”"
               Blendenflecke 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               BMP 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Buntglas-Mosaik 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Buntstiftschraffur 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Camera Raw 9.10 - aus der Datei "“Camera Raw.8bi”"
               Camera Raw-Filter 9.10 - aus der Datei "“Camera Raw.8bi”"
               Chrom 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Cineon.8bi”"
               Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Color Lookup-Raster rendern 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Export3DLUT.8be”"
               Color Lookup-Tabellen exportieren 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Export3DLUT.8be”"
               CompuServe GIF 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Conté-Stifte 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               De-Interlace 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Diagonal verwischen 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Dicom 18.1.1 - aus der Datei "“Dicom.8bi”"
               Differenz-Wolken 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Clouds.8bf”"
               Distorsion 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Dunkle Malstriche 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Durchschnitt 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Average.8bf”"
               Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“EazelAcquire.8ba”"
               Entropie 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Erfassungsbereich 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“MeasurementCore.8me”"
               Extrudieren 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Farbpapier-Collage 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Farbraster 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Fasern 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               FastCore-Routinen 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“FastCore.8bx”"
               Feuchtes Papier 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Filtergalerie 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Fluchtpunkt 18.1.1 - aus der Datei "“VanishingPoint.8bf”"
               Fotokopie 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Fotos freistellen und gerade ausrichten (Filter) 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Fotos freistellen und gerade ausrichten 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“CropPhotosAuto.8li”"
               Fresko 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Für Web speichern 18.1.1 - aus der Datei "“Save for Web.8be”"
               Gekreuzte Malstriche 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Gerissene Kanten 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Glas 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Grobe Malerei 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Grobes Pastell 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               HDRMergeUI 18.1.1 - aus der Datei "“HDRMergeUI.8bf”"
               HSB/HSL 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               IFF-Format 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               JPEG 2000 18.1.1 - aus der Datei "“JPEG2000.8bi”"
               Kacheleffekt 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Kacheln 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Kanten betonen 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Kohleumsetzung 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Konturen mit Tinte nachzeichnen 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Körnung && Aufhellung 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Körnung 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Kräuseln 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Kreide && Kohle 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Kreuzschraffur 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Kristallisieren 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Kunststofffolie 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               LAGE 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Leuchtende Konturen 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Malgrund 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Malmesser 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Matlab-Vorgang 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“ChannelPort.8bf”"
               Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Mehrprozessorunterstützung 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“MultiProcessor Support.8bx”"
               Mezzotint 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Mit Struktur versehen 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Mittelwert 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               MMXCore-Routinen 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“MMXCore.8bx”"
               Neigung 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Neonschein 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               NTSC-Farben 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“NTSC Colors.8bf”"
               Objektivkorrektur 18.1.1 - aus der Datei "“Lens Correction.8bf”"
               Objektivunschärfe 18.1.1 - aus der Datei "“Lens Blur.8bf”"
               Ölfarbe getupft 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               OpenEXR 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Ozeanwellen 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Patchwork 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“PCX.8bi”"
               Pfade -> Illustrator 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Photoshop 3D-Modul 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Photoshop3DEngine.8bi”"
               Photoshop Touch 14.0 - aus der Datei "“PSDX.8bi”"
               Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Pixar.8bi”"
               PNG 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Polarkoordinaten 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“PBM.8bi”"
               Prägepapier 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Punktieren 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Punktierstich 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Radialer Weichzeichner 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Radiance.8bi”"
               Rasterungseffekt 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Risse 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Schwamm 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Schwingungen 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Selektiver Weichzeichner 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Solarisation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“Solarize.8bf”"
               Spaces 18.1.1 - aus der Datei "“Spaces.8li”"
               Spritzer 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Standardabweichung 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Stempel 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Strichumsetzung 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Strudel 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Stuck 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Sumi-e 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Summe 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Targa 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Tontrennung && Kantenbetonung 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Topaz DeNoise 6 10.0 - aus der Datei "“tldenoise6ps_x64.8bf”"
               U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Unterstützung für Skripten 18.1.1 - aus der Datei "“ScriptingSupport.8li”"
               Varianz 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“statistics.8ba”"
               Verbiegen 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Verflüssigen 18.1.1 - aus der Datei "“Liquify.8bf”"
               Versetzen 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Verwackelte Striche 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Verwacklung reduzieren 18.1.1 - aus der Datei "“Shake Reduction.8bf”"
               Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“U3D.8bi”"
               Weiches Licht 18.1.1 - aus der Datei "“Filter Gallery.8bf”"
               Wellen 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               WIA-Unterstützung 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“WIASupport.8li”"
               Windeffekt 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
               Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - aus der Datei "“WBMP.8bi”"
               Wölben 18.1.1 - aus der Datei "“Standard MultiPlugin.8bf”"
            Optionale Zusatzmodule und Zusatzmodule von Drittanbietern: KEINE
            Doppelte und deaktivierte Zusatzmodule: KEINE
            Nicht geladene Plug-Ins: KEINE
            Erweiterungen:
               com.adobe.inapp.purchase  2.7.122 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
               Letzte Dateien  1.4.2 – aus der Datei “c:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
               Bibliotheken  2.7.122 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
               Neues Dokument  1.4.2 – aus der Datei “c:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
               Einstieg  1.4.2 – aus der Datei “c:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
               com.adobe.experimentation.extension  2.0.0 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
               Adobe Color-Themen  6.1.0 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
               Exportieren als  3.0.8 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
               Device Preview  1.3.1 – aus der Datei “c:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
               com.adobe.preview.loader  1.3.1 – aus der Datei “c:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
            Installierte TWAIN-Geräte: OHNE
            • 3. Re: "Select and Mask" causing WHEA_uncorrectable_error
              I can get the jest of the German I see you have a current Nvidia Driver no third party plug-ins, nothing failed to load and there are no duplicates, and both CC 2017 updates are installed. Two 1K displays 1GPU 1CLGPU enabled advance and true Initialized ready to go.
              I can not see any problem sorry I have no idea of what the problem is.  The only BSOD i have seen in years I believe was on a Windows 10 Preview Build and I think Microsoft has change the color now.
              • 4. Re: "Select and Mask" causing WHEA_uncorrectable_error
                M_Schloegl Level 1
                Yes, the system - normally - works perfectly.
                Now, what I've tried was raise the CPU Vcore frequency by a hair, a I'v read that sometimes the GPU asks more performance than the CPU can provide, so overclocking it by a hair can fix the issue.I'll be back in case I succee, or someone else finds a solution.
                Thanks anyway for taking the time!
                • 5. Re: "Select and Mask" causing WHEA_uncorrectable_error
                  M_Schloegl Level 1
                  A long, long night of BSODs later:
                  it seems like the crash is happening after a certain amount of work done with select and mask. If used very slowly, it seems to work for a bit, until the "never-stopping circle of software-thought" appears. THEN I have to click "Okay", succeeded by pressing Escape et voilà, it's there - without any possible manual refinement, but it's there. Same set, dark hair, HORRIBLE results, same set AND lighting, blonde, fantastic results.
                  After - wisely - saving the file, I can commence another attempt, on a small area, then okay & exit again.
                  It sems like there sort of a "reservoir" tha fills up, and then you have to stop pouring or it spills an crashes the whole machine.
                  I've had my eyes on both CPU and GPU load as well as RAM, CPU was around 50%, GPU around 11% and RAM whatever PS takes out. Maybe that helps solving the problem!
                  Otherwise, PS CC 2017 has been performing flawlessly. 14,5 hours of retouching and compositing, psd, psb, no issue EXCEPT said feature!
                  • 6. Re: "Select and Mask" causing WHEA_uncorrectable_error
                    M_Schloegl Level 1
                    So, after a couple more hours of experimenting, I found out that I can use select an mask as follows:
                    1. I mark an edge with the refine edge tool. This works fine, the workspace goes into a sort of preview mode with edges blurred and remains there, mostly. No tools (except Escape) are accessible.
                    2. I mark another edge, with the ever-spinning cursor still spinning, and wait.
                    3. After a couple of seconds, the edge appears refined.
                    4. Repeat Steps 1-3. If the tool is used between steps 2 and 3, the BSOD occurs. The same behaviour goes for quick select in select and mask mode.
                    I will now report this as a bug.
