1 Reply Latest reply on May 22, 2017 12:53 PM by Sheena Kaul Branched to a new discussion.
    Stock photos not high enough resolution  . . .
    ezrab23336697
      Hi.  I purchased a stock photo - the largest size - hoping that it would be sufficient to place on a large canvas print approximately 4 feet by 4 feet.  The resolution is not high enough.  How can I gain access to a higher resolution image?  Thank you
        • 1. Re: Stock photos not high enough resolution  . . .
          Sheena Kaul Adobe Employee
          Hi Erza,
          We generally have the Preview of the image which is a low resolution but since you have mentioned that you had purchased the image that means you have licensed the image which should give you the high-resolution image.
          You can also refer to the size of the image mentioned just below the image itself which gives you the idea.
          Please also see The Premium Collection | Adobe Stock which gives you the access to a diverse showcase of images, directly within the Creative Cloud applications they already use.
          Let me know if that helps!
          Regards,
          Sheena
          2 people found this helpful
