2 Replies Latest reply on May 23, 2017 12:26 AM by vinny38
    Printing Issue - Long Edge/Short Edge
      Hi, I'm printing a layout that is double sided but when I print Long Edge,  The Front side is towards the bottom of the page and the back side is towards the top of the page.   When I print on Short Edge the the Front side is towards the left of the page and the Back side is towards the Left of the page.
      How do I set it up to be perfectly aligned in the middle when I print. My printer doesn't seem to have any more option I can play with.
      My PDF preview looks correct So I'm pretty sure its a printer setting.
      Any help is appreciated.
        • 1. Re: Printing Issue - Long Edge/Short Edge
          Michael Witherell Adobe Community Professional
          What application are you printing from?
          What printer are you printing to?
          • 2. Re: Printing Issue - Long Edge/Short Edge
            vinny38 Level 4
            If I understand you correctly, your document is smaller than the page format output, right?
            If so, there are several ways to center your PDF on a paper sheet.
            Option 1:
            In Indesign, use "Print" feature (could be direct to printer, or to a PDF)
            Print feature allows you to set the paper size (Format du papier), and to center your artwork:
            Option 2 (the one I would personally use):
            In Acrobat Print panel, uncheck "Choose Paper Source By PDF Page Size", then set Orientation to "auto". See example below:
            Of course, these settings may vary depending on your OS (Mac, Windows?), software versions, use of a print manager and so on... so if you don't manage to solve your problem, please be more specific.
