3 Replies Latest reply on May 22, 2017 12:18 PM by john beardsworth
    Change caption text globally
    dbe4876 Level 1
      My book background is white, but my caption text is also white
      How can I change my caption text globally so that it is black (and 8pt instead of 9pt)?
        • 1. Re: Change caption text globally
          john beardsworth Adobe Community Professional & MVP
          Get into Book's thumbnails view, then use Edit > Select All Text Cells.
          This will also select the cover text which you may want to have a different colour and size. You can use Cmd+click (Mac) or Ctrl+click to deselect those text boxes, but it is fiddly.
          • 2. Re: Change caption text globally
            dbe4876 Level 1
            Thanks for the help but I feel this is a less-than-desirable approach (which you'd probably agree with). I already have a few title text blocks that I'd prefer not to change along with the captions. It would be better if the book module gave us easy edit access to the Presets for all of the text types. There may yet be a way to get there but thus far I haven't discovered it.
            • 3. Re: Change caption text globally
              It's the only way to do it. So the method is to use that menu item to select all text blocks, and then deselect those titles that you don't want to change. Or you can go through page by page, again using that menu command - in page view, it only selects the text boxes on that page.
